I just ran into this when trying to sort why my machines wouldn't shut down with my script.
On Ubuntu 20.04 Python is linked a different way than before in /usr/bin. Both python2.* and python3.* are linked to python2, and python 3 respectively. The kodi-send command is looking for python. As such I got the topic error on trying to fire it. I created a symlink from python2 > python under /usr/bin/ and solved the issue.
I'm unsure how to file this as a bug report as filing an issue asks for much more information than is needed, most of it not showing any problems. The problem is in the symlinks in /usr/bin/ on Focal, or lack thereof.
The only reason I know this is a change in 20.04 is that I just recently upgraded myself from 18.04. My script hasn't changed so it had to be the 20.04 change.
I'm no expert but can you also define this in a shebang within
/usr/bin/kodi-send
itself?
That would also solve it. Either way /usr/bin/python no longer exists.
It's a packaging issue more than a bug. I'm not sure how to report that properly.
*EDIT* I just filed a but report, I hope properly. Will see what happens.
(2020-11-04, 20:53)jmgibson1981 Wrote: [ -> ]That would also solve it. Either way /usr/bin/python no longer exists.
Isn't that a fault at OS level?
I thought /usr/bin/python should be symlinked to the latest version, so shebangs always pick up the OS default. Most package updates usually take care of that.
(2020-11-21, 14:05)Preacher Wrote: [ -> ]Isn't that a fault at OS level?
Nope, this is documented.
https://wiki.debian.org/Python (same applies to ubuntu as ubuntu inherits most of debian's advantages and flaws )
Quote:NOTE: Debian testing (bullseye) has removed the "python" package and the '/usr/bin/python' symlink due to the deprecation of Python 2. No packaged scripts should depend on the existence of '/usr/bin/python': if they do, that is a bug that should be reported to Debian. You can use the 'python-is-python3' or 'python-is-python2' packages to restore an appropriate '/usr/bin/python' symlink for third-party or legacy scripts.
Edit: In the case of kodi-send I totally agree that the best way to fix it would be to simply change the shebang locally.
(2020-11-21, 17:27)asavah Wrote: [ -> ] (2020-11-21, 14:05)Preacher Wrote: [ -> ]Isn't that a fault at OS level?
Ahh... I see!
Would it be better to use
python:
#!/usr/bin/env python
as the first line, rather than explicitly specify a version?
At least that way it's delegating the location of the python binary to the OS and decoupling it from environment presumptions.
On Arch both python2 and python3 (called just python) co-exist so that's why I recommended it. I do not know about others distros.
(2020-11-21, 21:50)Preacher Wrote: [ -> ]Would it be better to use #!/usr/bin/env pythonPython as the first line, rather than explicitly specify a version?
No, because on debian based distros there is no "python" by default now, unless you install a python-is-python* package.
/usr/bin/env python2
makes sense tho.
(2020-11-21, 22:39)graysky Wrote: [ -> ]On Arch both python2 and python3 (called just python) co-exist so that's why I recommended it. I do not know about others distros.
On arch /usr/bin/python is a symlink to /usr/bin/python3.
On debian the decision was that this might cause unexpected issues with legacy stuff, so it's better to fail because of missing shebang and let the user examine and fix the situation, rather then do something unexpected.
