Hi all, I'm trying to setup TVHeadend on an Rpi 3, but the webgui won't see my tuner - Winfast DTV Dongle Gold. If I run lsusb I can see it that way as:
Bus 001 Device 006: ID 0413:6029 Leadtek Research, Inc. WinFast DTV Dongle Gold
It just won't appear under TV adapters in configuration-DVB inputs
Any suggestions on how to get it to work? Or am alternative that will work easily with rpi?
(2020-11-06, 04:31)blueman83 Wrote: [ -> ]Any suggestions on how to get it to work?
Let's start with which OS you are running on your RPi-3.
(2020-11-06, 09:35)Klojum Wrote: [ -> ] (2020-11-06, 04:31)blueman83 Wrote: [ -> ]Any suggestions on how to get it to work?
It's running the latest version of Raspberry Pi OS (the old Raspbian)
Probably needs firmware. Look in dmesg and see what the kernel is identifying it as.
As per the subtle clue in red above the posting buttons, please use paste.kodi.tv for such outputs rather than spamming the forum with them...
Yep, firmware needed
[Fri Nov 6 10:20:52 2020] usb 1-1.5: dvb_usb_v2: found a 'Leadtek WinFast DTV Dongle Gold' in cold state
[Fri Nov 6 10:20:52 2020] usb 1-1.5: Direct firmware load for dvb-usb-af9015.fw failed with error -2
[Fri Nov 6 10:20:52 2020] usb 1-1.5: dvb_usb_v2: Did not find the firmware file 'dvb-usb-af9015.fw' (status -2). You can use <kernel_dir>/scripts/get_dvb_firmware to get the firmware
[Fri Nov 6 10:20:52 2020] dvb_usb_af9015: probe of 1-1.5:1.0 failed with error -2
This link may also help
https://www.linuxtv.org/wiki/index.php/L...ongle_Gold
This is resolved now, thankyou!
