Full Version: Live TV don't work (Player doesn't start)
Hello,
i am a new Kodi User, in the passed i use Mediaportal 2 only. Now i want to try Kodi for one new TV.
I buyed the following Android TV Box and installed Kodi 18.9 from the App Store.
https://www.ebay.de/itm/8K-H9-Android-9-...edeca67bf3
I have added my MediaShares and Movies and Series works very fine, but the TV Section won't work.
The connection to the MP2.3 Server with Kodi Plugin works and the Channels are imported to Kodi.
But if i want to start a Channel the Player doesn't start. But on the TV Server i can see that the Kodi Client starts the channel and the Timeshift Buffer starts.
When i stop the Channel, then it takes 5min that the Timeshift stopps. In this time the Kodi Client freeze.
My MP Server is a Win10 Computer without Monitor or any Screen and the Timeshift Folder is a Local HDD Folder in the Server which is shared for all Users in the network.
Can any one help or any one have the same Problem?
I hope i habe explain my problem well.
Solved!
I swich on the RTPS Stream Option in the Add On, now the player starts.
Is there any Problem with RTPS?
In every description i read, they said that this Option must be disable.
