2020-11-11, 21:16
I like to rename my tv shows in a singular way
TV Show folder name: TV show name (year) [STATUS] [Resolution VideoCodec Audio Codec] [Dual + Subs]
Season folder name: Season # [Resolution VideoCodec Audio Codec] [Dual + Subs]
For example..
The Night Of (2016) [ENDED] [1080p x265] [Dual + Subs] \ Season 1 [1080p x265 AC3] [Dual + Subs] \ ....
I have realized that I can setup in TMM v.4 the expresion to rename folder, as follow:
Season ${seasonNr} [${if episode.mediaInfoVideoFormat='2160p'}4K${else}${episode.mediaInfoVideoFormat}${end} ${if episode.mediaInfoVideoCodec='h264'}x264${else}${if episode.mediaInfoVideoCodec='h265'}x265${else}${episode.mediaInfoVideoCodec}${end}${end} ${episode.mediaInfoAudioCodec}]${if episode.mediaInfoAudioCodecList.length = '1' } ${else} [Dual${if episode.mainVideoFile.subtitles} + Subs${end}] ${end}
However, if I try to put this expression in TV show folder name, it keeps ignoring any reference.
For example, if I write this in Season folder name:
${showTitle} (${showYear}) [${showStatus}] --> It works perfectly
${showTitle} (${showYear}) [${showStatus}] [${if episode.mediaInfoVideoFormat='2160p'}4K${else}${episode.mediaInfoVideoFormat}${end} ${if episode.mediaInfoVideoCodec='h264'}x264${else}${if episode.mediaInfoVideoCodec='h265'}x265${else}${episode.mediaInfoVideoCodec}${end}${end} ${episode.mediaInfoAudioCodec}] --> It ignores completely everything after "showstatus"
Why regultar expressions doesn't seem to work in the TV show folder name?
And another simple question... If I put ${showStatus} if gives me either "Ended" or either "Continuing". Is there any way to capitalize the result to have "ENDED" or "CONTINUING"?
For example..
