Full Version: Xbox Series X Won't play back H265 4k content
Pages: 1 2
Just picked one up yesterday and everything is working fine outside of playing back H265 4k content.  The app just completely crashes when I go to play anything back.  Every other video source I've thrown at it is working fine but this has me stumped.  It appears like it could be a DX driver issue which would make some since with the new hardware only being released.
Here is my log
https://paste.kodi.tv/awicunilev.kodi
Thanks for any help
I can’t help, but I have the same issue.
It might be because Kodi doesn't (or isn't allowed?) access the whole system.
The specified device interface or feature level is not supported on this system.
(2020-11-12, 12:24)Hitcher Wrote: [ -> ]It might be because Kodi doesn't (or isn't allowed?) access the whole system.
As a side note I did play back the same files in VLC on the series X, so I'm thinking the access's may be there. Should I submit a bug report (and does the log have enough data in it)?
(2020-11-12, 15:49)imimmortl Wrote: [ -> ]
I've had the same issue, moving from a One X to Series X.
Disable DXVA in the settings, then you have the VLC experience. Might stutter a log, though.
(2020-11-12, 19:50)fritsch Wrote: [ -> ]
Disabling dxva didn’t fix it.
(2020-11-13, 12:06)Raging10 Wrote: [ -> ]
(2020-11-12, 15:49)imimmortl Wrote: [ -> ]As a side note I did play back the same files in VLC on the series X, so I'm thinking the access's may be there. Should I submit a bug report (and does the log have enough data in it)?
I have the same issue and also, disabling dxva didn't solved it for me.
In my case (XBox One X though), activating "Adjusting display refresh rate" leads to video stutter and delays in starting videos, so I kept it off. I've also experienced issues with activating "Sync playback to display", so I keep it off as well. All workarounds though. I know that @jogal fixed several bugs in the Windows (UWP) implementation in recent months. As such, it is probably worthwhile to retest all this once Matrix releases.
(2020-11-13, 18:55)M4tt0 Wrote: [ -> ]In my case (XBox One X though), activating "Adjusting display refresh rate" leads to video stutter and delays in starting videos, so I kept it off. I've also experienced issues with activating "Sync playback to display", so I keep it off as well. All workarounds though. I know that @jogal fixed several bugs in the Windows (UWP) implementation in recent months. As such, it is probably worthwhile to retest all this once Matrix releases.
Kodi ran fine on my Xbox one X. Something going on with the series x.
Hello,
Same problem there. Kodi was perfect on my Xbox One X (2160p + TrueHD / 2160p + DTS-HD / 2160p + AC3 ...), but since I have and installed Kodi on my new Xbox Series X, only the HD and SD videos are good. All the 2160p doesn't work anymore, the software crash each time I try to play a video in 4K ... I hope there will be an uptade soon for this wonderful software ! Wink
(2020-11-14, 17:06)filipandman Wrote: [ -> ]I hope there will be an uptade soon for this wonderful software
Willing to donate a Series X to a dev?
Same issues, kodi crashes with 4k content. Following.
Looks like several users are having the issues.  Should a issue ticket be submitted?
Pages: 1 2
