Jumpy73
I don't believe KODI recognizes NFO files for Sets...just the Movies in the Set. Someone else correct me if I'm wrong.
What info are you trying to update for the Set?
I love the work that you've done. Impressive
Where can I find the option to choose for the right tagformat like f.e. %# - %T or only %T when listening music?
Athenatius Track naming template is set in Kodi Settings, Media, Music.
Yes, that was the first place I checked. Still don't see it?
Athenatius Do you have your settings level set to Expert? And did you page down far enough...that setting is near the bottom.
That's it! I didn't set it to expert.
Much obliged.
By the way,
The only thing is that the tagformat on visualisation setting is not right ( in normal setting it's ok now).
Tracknumber is double, no matter which format I choose.
Check out what I mean:
Tag format
Hi @
Athenatius !
It is not a matter of Kodi: Take a look at the file format and check with e.a.mp3tag!
I remember this from some files.
Greetz
Klaus
Yeah, it has to do with the way I've tagged my collection.
Wanna keep it that way.
I will get used to it.
Possible to add a fallback background image If artist fanart isn't available while playing music? Currently I have Artist Fanart set in Layout 7, If I select "Background set by user" then it disables Artist Fanart, I imagine that this is by design, but it would be nice if there was a way I could set some sort of generic background image if there were no Artist Fanart available.
