2021-09-14, 03:47
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170
2021-09-14, 13:23
@grimmace92
I fixed my problem by deleting simplecache.db. I'm running Skin Helper Service v1.1.39 and Metadata v1.0.41.
2021-09-14, 16:38
(2021-09-14, 13:23)latts9923 Wrote: [ -> ]@grimmace92
There is a Metadata v1.0.42 version that works as well.....
script.module.metadatautils V.1.0.42
2021-09-14, 23:30
Unfortunately it won't work. Did a fresh install and copied the advancedsettings.xml from another machine as I use mysql. Occassionally a movieset studio logo will show but thats it. I see these errors in the log ERROR <general>: DoWork - Direct texture file loading failed. Still think this is possibly a mysql issue but not sure
So I tested removing the advancedsettings.xml and a smaller library and it works. Something isn't right when its a mysql setup
2021-09-16, 00:22
(2020-11-13, 21:04)latts9923 Wrote: [ -> ]Aeon MQ 8 Matrix Mod v1.0.1.4 for Kodi v19 "Matrix"
There are some areas that are not functional yet...still waiting on some Add-ons to be updated for Matrix.
Installation Guide
- Install my repo (https://holybid.com/kodi/lattsrepo/maste....lattsrepo)
- Install the Marcelveldt repo (https://github.com/kodi-community-addons...-1.0.3.zip)
- Install Skin Helper Service from the Marcelveldt repo (located in Context Menus)
- Install ExtendedInfo Script from my repo (located in Program add-ons)
- Install Aeon MQ 8 for Matrix from my repo (located in Look and Feel > Skin)
- When you access Skin Settings, Kodi will prompt you to install the Skin Helper Service Colorpicker add-on.
- While you are in Skin Settings, scroll down to Add-ons. This will show the installation status of additional add-ons that MQ 8 uses. Select "Install All Add-ons Now (Selective Mode)" and you can choose one at a time which add-ons you would like to install.
- Install the optional Add-ons below...
Optional Add-ons (Some available to install from my repo)
- Aeon MQ Skinthemes
- Additional Aeon MQ themes (You can copy these themes from this file into the Aeon MQ Skinthemes Add-on after it is installed)
- Artwork Helper v0.9.2
- Colored Flag Add-ons
- Colored Media Icons v0.1.6
- Library Editor v3.0.0
- Skin Info Service v1.1.2
- TV Show - Next Aired v8.0.1
- TVTunes v2.0.4 (There is still a problem with the video themes not stopping once they begin to play and you select another Movie.)
Skin download (For those who would like to manually download the skin)
A few notes...
- The skin includes the latest updates that were posted in the Aeon MQ 8 Multi-Mod thread.
- The Skin Helper Service is not 100% yet...it continues to be updated for Matrix.
- The Video Info screen will now display Sets info. There is still room for improvement with this new feature of the skin.
Automated Skin Settings
Updates
11/22/20 - Update for v1.0.0.0. Read here for more info.
12/05/20 - Update for v1.0.0.1. Read here for more info.
12/12/20 - Update for v1.0.0.2. Read here for more info.
12/30/20 - Update for v1.0.0.3. Read here for more info.
01/23/21 - Update for v1.0.0.4. Read here for more info.
02/05/21 - Update for v1.0.0.5. Read here for more info.
02/13/21 - Update for v1.0.0.6. Read here for more info.
02/21/21 - Update for v1.0.0.7. Read here for more info.
03/21/21 - Update for v1.0.0.8. Read here for more info.
04/10/21 - Update for v1.0.0.9. Read here for more info.
04/30/21 - Update for v1.0.1.0. Read here for more info.
05/23/21 - Update for v1.0.1.1. Read here for more info.
07/02/21 - Update for v1.0.1.2. Read here for more info.
09/06/21 - Update for v1.0.1.3. Read here for more info.
@latts I'm trying to find MQ8 Matrix from point 5 above but it's not showing when I go to look and feel. Only showing MQ7. Any suggestions? Thanks
2021-09-16, 02:05
(2021-09-16, 00:22)mataus19 Wrote: [ -> ](2020-11-13, 21:04)latts9923 Wrote: [ -> ]Aeon MQ 8 Matrix Mod v1.0.1.4 for Kodi v19 "Matrix"
Installation Guide
A few notes...
Updates
Are you in the right repo?
2021-09-16, 08:37
(2021-09-16, 00:22)mataus19 Wrote: [ -> ]Hi,(2020-11-13, 21:04)latts9923 Wrote: [ -> ]Skin download (For those who would like to manually download the skin)
go this way to download the zip and install it from the Addon-Menu. The easy way...
2021-09-16, 10:19
2021-09-16, 13:03
(2021-09-16, 02:05)wags1 Wrote: [ -> ]My bad,(2021-09-16, 00:22)mataus19 Wrote: [ -> ](2020-11-13, 21:04)latts9923 Wrote: [ -> ]Aeon MQ 8 Matrix Mod v1.0.1.4 for Kodi v19 "Matrix"
Installation Guide
A few notes...
Updates
I'm using a Odroid N2 running latest CoreElec version 9.2.8 (Stable) and assumed that this was Matrix and it seems not. I have to use the '19.2-Matrix_rc3' beta version. Hence why it probably isn't showing the Matrix versions and also why I can't get Artwork Dump to install.
Cheers anyway for the advice!
2021-09-17, 03:08
@latts9923 I'm trying to get all the coloured icons to show correctly on the dialogue page. Most of them show if the filename contains the relevant info. An example of how I label my files is:
moviename (year).2160p.hevc.hdr.10bit.atmos.8ch.mkv
I cannot get the video resolution icon to show 4K Ultra HD no matter what I put in the filename. I've tried '4k', 'uhd'. However the fact that 2160p is in the filename then it should work.
Is there anyway we can link the '2160p' in the filename to the 4K resolution icon along with the 'UHD Bluray' icon in audio codec?
I would be grateful if you could point me to the relevant XML files like 'include variables' so that I can see what I filenames I should use in order to get the correct aspect ratio, audio codec. resolution etc. Thanks!
2021-09-17, 08:02
(2021-09-17, 03:08)mataus19 Wrote: [ -> ]@latts9923 I'm trying to get all the coloured icons to show correctly on the dialogue page. Most of them show if the filename contains the relevant info. An example of how I label my files is:
Hi there,
I had very much the same issue as you. After much tinkering with video filenames, I eventually came across a solution that works for me.
In the folder .kodi/addons/resource.images.resolution.color/resources/ I had to capitilise the 'K' in the 4K.png filename for the icon to appear.
Hope this helps.
M
2021-09-17, 11:40
(2021-09-17, 08:02)thesabear Wrote: [ -> ][quote="mataus19" pid='3060571' dateline='1631840919']
Hi there,
Hope this helps.
M
[/quote
Thanks I'll give that a try]
2021-09-19, 05:43
Anyone know of a way to rearrange the context menu in the video info window? To me it makes more sense to have either the play button on the far left or the play button change to resume if the the movie/tv show has already been started but not finished. Is there a plugin or something that i can install to change this?
I know that resume functionally does the same thing as play...but it does not make sense to me to "resume" if I'm watching a new movie or tvshow that i haven't watched yet.
2021-09-19, 13:41
@mataus19
Look in IncludesVariables.xml for ""audiocodec". I can add a '2160p' to the resolution to display the 4K icon. You can add the UHD Bluray icon to the audiocodec flags, but you would need to add a unique extension like ".audiouhd.".
@Shredder_guitar
That's a good idea. I can make the play button be displayed first. It will be a while before I can release another update, so if you want to move it yourself now open DialogVideoInfo.xml and find...
Underneath that, find...
Move that above...
@Shredder_guitar
xml:
<control type="list" id="149">
<visible>![Container.Content(sets) | ListItem.IsCollection]</visible>
xml:
<!-- Iniciar -->
<item id="3">
<label>31700</label>
<onclick>SendClick(2003,8)</onclick>
</item>
Move that above...
xml:
<!-- Resume -->
<item id="2">
<label>13404</label>
<onclick>SendClick(2003,9)</onclick>
</item>
2021-09-20, 15:19
(2021-09-19, 13:41)latts9923 Wrote: [ -> ]@mataus19
@Shredder_guitar
xml:
xml:
<!-- Iniciar -->
<item id="3">
</item>
Move that above...
xml:
<!-- Resume -->
<item id="2">
</item>
ahhhhh, much better, thank you sir!
little note for anyone else wanting this, there are 2 places in the dialoginfo.xml this needs applied
