2022-01-19, 04:40
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170
2022-01-19, 04:40
2022-01-20, 14:28
Is there a way to display audio channels in movies, music etc... (bottom of the screen) in color?
2022-01-20, 15:42
@Jumpy73
I updated the link for the Colored Media Icons. I only have one link (my repo) for the Colored Media Icons. The other resource.image.XXX.zip files are linked in the first post as Colored Flag Add-ons. I have updated some of those with new icons in my repo. I'll go ahead and make them all available in my repo. Thanks for the suggestion.
@Shredder_guitar
I'll take a look at the code for views 6 & 7.
@andrzejls
You can access all the colored icon Add-ons in the first post of this thread...the link is named Colored Flag Add-ons. As stated above, I've updated some of these (you should see updates available if you have my repo installed) and I will move the rest to my repo so that you can access them all in one place. Once installed, you can enable them in Skin Settings.
@Shredder_guitar
@andrzejls
2022-01-20, 16:27
(2022-01-20, 15:42)latts9923 Wrote: [ -> ]@latts9923
@andrzejls
Thanks for quick replay. have them installed and in skin setting "icons and images" "audiocodec.color" and "audiochannels.color" are installed. I must be missing something. Which setting/add-on controls audio codecs (speaker icon, 5.1) color display?
Update:
I found the needed setting. It turns out that I needed to install "Media icons pack for AEON MQ 7-Coloured" in "ICONS AND IMAGES" "AUDIO:SUBTITLE". Go figure, MQ 7 addon for MQ 8.
2022-01-20, 20:05
Hi @latts9923
I am having some troubles with the displaying of Studio icon in the Media bar (in some cases it is not even present in the movie details "Country/Genre/Studios") for some movies. I opened the <movie>.nfo file, checked the content in the video library using the "Library Editor Script" script and the decompiled content of the Texture.xbt file of the "resource.images.studios.coloured" resource. The name enclosed in the <studio> tag of .nfo file is the same one loaded in the video library and is also present in the Texture.xbt file. For the sake of scruple I also deleted the simplecache.db file and then restarted Kodi but nothing ... the study icon is not displayed even if it is present in the resource file!
There is definitely something wrong with the installation, sometimes Skin Helper Service (v1.1.40 MarcelVeldt) returns errors and in the kodi log there are many lines with the word "ERROR ...", for example "ERROR <general> : CImageLoader :: DoWork - Direct texture file loading failed for resource: //resource.images.studios.coloured/ "but I don't know if there is a correlation. This is getting too complicated for my skills!
If of interest for someone, please find here the kodi log. Hope this helps for eventually understanding the issue
I would really appreciate if you or someone else could point me in the right direction.
Thanks and regards
Thanks and regards
2022-01-20, 20:49
@Jumpy73
The mentioned error in your log is caused by a missing studio image file when compared with the value in the Kodi database, where the name needs exactly equal to work. The only way to stop the error message is to create one art for each studio art missing in the texture package.
2022-01-20, 21:25
(2022-01-20, 20:05)Jumpy73 Wrote: [ -> ]If of interest for someone, please find here the kodi log. Hope this helps for eventually understanding the issue
script.module.metadatautils v1.0.38 installed
is old version, nneed to update on version="1.0.45"
That version cousing isue with animated Art, and your log is full of that errors.
this error I don't understand
ERROR <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/Marvel Studios.png
Are you ?
2022-01-21, 00:38
(2022-01-20, 21:25)Angelinas Wrote: [ -> ]script.module.metadatautils v1.0.38 installed
I had installed version="1.0.38" from @latts9923 repo, now I've installed version="1.0.45" from @marcelveldt repo and the studios icons are displayed correctly.
A movie has "New Regency Productions" as studio. An icon with the same filename is not included in the current Texture.xbt file of the "resource.images.studios.coloured" resource. So I tried to directly add the file in the same directory of current Texture.xbt file but it doesn't work. How can I do it? (please see the screenshot)
(2022-01-20, 21:25)Angelinas Wrote: [ -> ]this error I don't understand
I see in your log that you have "resource.images.studios.coloured", look like you disable this resource addon.Code:ERROR <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.studios.coloured/Marvel Studios.png
Are you ?
No, the "resource.images.studios.coloured" resource addon is enabled, or it appears to be in such a way (please see the screenshot)
Anyway I don't understand these errors too
ERROR <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.moviegenrefanart.panel/3 Days to Kill.jpg
ERROR <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.moviegenrefanart.panel/Avengers - Collezione.jpg
Why does kodi have to try to load an image file named <movie name>.jpg or <movie set name>.jpg for moviegenrefanart purposes?
Please find here the new kodi log after the before mentioned modifications. It appear to me that many errors on "resource.images.xxx" addons still remain into the kodi log
2022-01-21, 01:27
(2022-01-21, 00:38)Jumpy73 Wrote: [ -> ]I had installed version="1.0.38" from @latts9923 repo, now I've installed version="1.0.45" from @marcelveldt repo and the studios icons are displayed correctly.Now you have problem with cach image....for that "New Regency Productions" image is empty in your Thumbnails folder or db
(2022-01-21, 00:38)Jumpy73 Wrote: [ -> ]Anyway I don't understand these errors too
Code:ERROR <general>: CImageLoader::DoWork - Direct texture file loading failed for resource://resource.images.moviegenrefanart.panel/3 Days to Kill.jpg
<!--* Genre Fanart *-->
<control type="image">
<left>$PARAM[left]</left>
<top>$PARAM[top]</top>
<width>$PARAM[width]</width>
<height>$PARAM[height]</height>
<include condition="Skin.HasSetting(keepaspect)">KeepAspect</include>
<texture>$INFO[Skin.String(resource.images.moviegenrefanart.path)]$INFO[ListItem.Label,,.jpg]</texture>
<include>animation_panscan</include>
<visible>![Container.Content(seasons) | Container.Content(episodes)] + [!Player.HasVideo | Player.HasVideo + !Skin.HasSetting(background_live)] + $PARAM[visible] + [Window.IsActive(videos) + String.IsEqual(skin.string(videogenrefanart),genre)]</visible>
</control>
2022-01-21, 01:43
(2022-01-21, 01:27)Angelinas Wrote: [ -> ]Now you have problem with cach image....for that "New Regency Productions" image is empty in your Thumbnails folder or dbHow can I solve it?
(2022-01-21, 01:27)Angelinas Wrote: [ -> ]What can I do? I suppose nothing from my sideThis is bad visible condition....Code:<!--* Genre Fanart *-->
</control>
Anyway something wrong is critic for kodi stability because it often crashes without an apparent reason
2022-01-21, 02:29
(2022-01-21, 01:43)Jumpy73 Wrote: [ -> ]@'Jumpy73"(2022-01-21, 01:27)Angelinas Wrote: [ -> ]Now you have problem with cach image....for that "New Regency Productions" image is empty in your Thumbnails folder or dbHow can I solve it?
</control>
If you run Windows use "SQLyog" software or if you run Lunux "DBeaver". Connect to your kodi MyVideos119.db. Open "movie" table find your movie that you are missing studio info. If it is not there just type studio name. Open "studio" table and check that studio name is there, if not add new row and add studio name. This will work if the studio name.png is in Textures.xbt. Fill in studio name, save database and restart kodi.
2022-01-21, 11:17
(2022-01-21, 02:29)andrzejls Wrote: [ -> ]@'Jumpy73"
Hi @andrzejls
for doing what you suggest do I have to follow the instructions as below?
- MySQL/Setting up MySQL (install & setup a MySQLserver for granting access to Kodi)
- MySQL/Setting up Kodi (connect kodi to MySQLserver at kodi startup)
- Direct Connection using MySQL C API (install & setup SQLyog client for directly connecting to MyVideos119.db internal library database)
Is it correct? or
Do you have in mind something else for directly connect SQLyog client to MyVideos119.db kodi database?
In the last case do you know where I can find an "how-to" procedure for doing that?
Regards
2022-01-21, 12:14
(2022-01-21, 11:17)Jumpy73 Wrote: [ -> ]Yes, you need to go through all 3 steps to set-up access to database.(2022-01-21, 02:29)andrzejls Wrote: [ -> ]@'Jumpy73"
Hi @andrzejls
Is it correct? or
Regards
2022-01-21, 12:27
I noticed that in MOVIES "Information" screen "Country" field in some movies is showing US flag and in some is empty. I did some digging and found out that movie information provider "THE MOVIE DATABASE PYTHON" creates entry in MyVideos119 database table "movie" column "c21" for the Country. When only 1 (one) Country is listed than Movie Information screen Country field is showing the flag of that Country. When multiple countries ("United Kingdom / United States of America" for instance) are listed in the c21 column then Country field in Movies Information screen is empty.
latts9923, could this be fixed?.
2022-01-21, 23:38
@Shredder_guitar
I fixed the problem with the album cover not displaying for layout 6 & 7.
@andrzejls
When I added the audio/subtitle flags to MQ 8 I kept the code from MQ 7 that uses the Colored Media Icons. There's really no need though when the Colored Audiochannels for MQ 8 has the required icons. I can look at changing the code to use that Add-on instead.
@Jumpy73
@Angelinas
I fixed the code for Genre Fanart. Thanks Angelinas for finding that!
@andrzejls
I have a fix for the Country Flag not displaying when there are multiple countries in the database. It will be part of the next update.
@andrzejls
@Jumpy73
@Angelinas
@andrzejls
