I just reinstall Kodi and wanted to start fresh, add library to tv shows and now kodi dont show any tv show at all.
Before i reinstall, Kodi show everything. I dont change nothing, i go to files, find tv show folder, and it to tv show library, and go to tv shows, and Kodi dont show anything?
Its everything like used to be, Tv shows folder- folder of each tv show- s01ex.
123321
Please provide a
Debug Log which captures you trying to add a tv show to the library. We should be able to see what the problem is.
kodi.log have 37 pages, should i put take a pic of every page?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I use Kodi on firestick, i use only remote so its hard to do this.
- Install the log uploader addon.
- Enable the debug logging.
- Reboot your stick.
- Reproduce your issue.
- Upload the log via the addon.
That will minimise the log size and allow upload, even just using a remote.
See the wiki for more details -
debug log (wiki).
(2020-11-14, 12:58)DarrenHill Wrote: [ -> ]- Install the log uploader addon.
See the wiki for more details - debug log (wiki).
http://paste.kodi.tv/ubidewavef
(2020-11-14, 13:49)123321 Wrote: [ -> ]http://paste.kodi.tv/ubidewavef
Thanks, but no good. You did not enable debug mode which is the very first step of the instructions.
Also you did not scan a tv show.
(2020-11-14, 22:22)Karellen Wrote: [ -> ] (2020-11-14, 13:49)123321 Wrote: [ -> ]http://paste.kodi.tv/ubidewavef
Sorry and thanks. Now i scan.
Thanks, now i have another question.
When i get description for some movie or tv show, can i somehow get this in language i want?
Because i see that on TMDb have a lot languages.
Assuming the language translation exists at TheMovieDB, you can.
Change the Preferred Language shown in section 4.1 in that wiki page.
Thank you soo much!!
I have another question, i am not sure. When i choose another language, will then i must set movie names also in another language or i can somehow set English name another language movie info?
(2020-11-16, 22:45)123321 Wrote: [ -> ]When i choose another language, will then i must set movie names also in another language or i can somehow set English name another language movie info?
In most cases it will work if you leave the English title.
But it assumes that the English name (or whatever language you named the movie) exists at TheMovieDB.
For example if the movie at TheMovieDB only has a Russian translation, then the scraper has nowhere to lookup the English name, so it will not work.
So if you find it does not work, then check what TheMOvieDB has recorded.
Thank you for all the help you give to me!!
You can lock the theme!
