Full Version: Need help with HDCP support - Firestick
I have some average TV that doesn't support HDCP standard. Firestick just show first logo and then black screen appears. Is there a way to disable HDCP on Firestick or is there a some adapter for HDMI to avoid this? Firestick on others tv works fine. If I need adapter can you recommend me the one that doesn't cost too much - under 15$...
(2020-11-15, 10:10)lasof123 Wrote: [ -> ]Is there a way to disable HDCP
Alas we are not a firestick support forum, and in any case the HDCP handshaking would be breaking copy-write and the forum rules. Suggest you visit https://en.wikipedia.org/wiki/High-bandw...Protection and have a peek at Official:Forum rules (wiki) although I suspect your issue is not one of HDCP.
