Full Version: HBO Max
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
When running on kodi18.9, the screen is always stuck, even if the resolution is adjusted to the lowest and H.264 decoding is used, the stuck situation still appears.
I am running kodi on google tv, this device is DRM L1
Stuck?
Full debug log please
(2021-05-16, 21:18)matthuisman Wrote: [ -> ]Stuck?
Sorry, the reply was late. The following is the log of "stuck" at the time. Because of my bad English, I don’t know how to describe this "stuck", or it can be called "screen freeze". The attached picture corresponds to the frozen screen. .
In addition, the CPU occupancy rate was relatively high at that time, reaching 100+%.
In addition, this problem also occurs on Amazon Fire TV 4k.
log : https://paste.ubuntu.com/p/Xhc6ywFfRq/
image :  https://ibb.co/7jw6Gd3
Try changing the audio stream to AAC 2.0 and see if that fixes
(2021-05-21, 10:52)matthuisman Wrote: [ -> ]Try changing the audio stream to AAC 2.0 and see if that fixes
Yes! It's really the problem here, just modify it to AAC 2.0. Thank you so much!
In addition, where can I change it to Audio AAC 2.0 by default? Now I make changes in the settings every time I play a movie.
just pushed 0.31.0.
Once you update, go into add-on settings and make sure both EC-3 and AC-3 are disabled (which is default)
This issue is actually a bug in either Inputstream Adaptive or Kodi that needs to be looked into.
It was only discovered that audio was the cause this week.
(2021-05-21, 11:36)matthuisman Wrote: [ -> ]just pushed 0.31.0.
Good job!
But which add-on do you mean by 0.31.0?
oops, I meant 0.2.6 of HBO Max Smile
You can force update by following:
https://www.matthuisman.nz/2019/09/how-t...d-ons.html
(2021-05-21, 12:20)matthuisman Wrote: [ -> ]oops, I meant 0.2.6 of HBO Max Smile
Greetings,
After updating to the latest version, I noticed a few titles aren’t playing anymore, while other titles seem to have no issue. For example, when attempting to play an episode from the adult swim collection (Brak Show or Aqua Teen Hunger Force to name two), episodes won’t play. Shows like Dave Chappelle, for example, have no issues playing. I tried with both the suggested fixes above enabled and disabled; however, the issue is still occurring. Any idea on a workaround for this issue?
I am running this on 18.7 Leia.
(2021-05-22, 09:20)jgoodwi3232 Wrote: [ -> ]
Greetings,
Here is a link to the debug log (I included the logs of a working video and a non-working one):
https://paste.kodi.tv/wicuciqoxi.kodi
Full debug log please...
Actually, never-mind.
I can see the issue. HBO have tightened up even more on non-secure (L3) widevine.
They now don't allow anything with a height of 720 or more.
Just pushed 0.2.6 that should fix your issue Smile
(2021-05-23, 23:20)matthuisman Wrote: [ -> ]Full debug log please...
I was just about to attach a full debug log and then saw you just pushed the update. Everything works great now Smile ---Thank you! Great work as always.
It would be nice if you could support Media Import for those that don't have plex and emby
https://forum.kodi.tv/showthread.php?tid=224794
HBO max has just lanched in Brazil, it will ever run? I tried to log in and it says the only country avaliable is US
Working on that now.
Needs a few changes
I also need a non USA login to test with.
If you can help, flick me a private message.
Remember to change your password to something random and unique to only HBO for your own piece of mind.
