Full Version: HBO Max
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
(2021-06-30, 21:12)matthuisman Wrote: [ -> ]Working on that now.
Needs a few changes
I also need a non USA login to test with.
If you can help, flick me a private message.
Remember to change your password to something random and unique to only HBO for your own piece of mind.
I was using a friend account, ill check with him, if not i'll get one account soon and I would be happy to help, thanks for replying
@Rick987
just pushed 0.2.8 (https://github.com/matthuisman/slyguy.ad...5f52b2123c) which adds initial support for other regions.
I didn't have another region login to test with, so can't be 100% it's going to work...
But it should be pretty close.
Please try and let me know.
I try to login, but it showme an error
(2021-07-01, 05:12)matthuisman Wrote: [ -> ]@Rick987
I tried and got the same error
xml:
2021-07-01 13:21:01.670 T:11368   ERROR <general>: CGUIMediaWindow::GetDirectory(plugin://slyguy.hbo.max/?_=login) failed
2021-07-01 13:21:01.819 T:12540    INFO <general>: initializing python engine.
2021-07-01 13:21:01.830 T:12540    INFO <general>: CPythonInvoker(17, D:\Kodi19.0\portable_data\addons\slyguy.hbo.max\default.py): script successfully run
oops. forgot to test in Kodi 18 (Python2)
Fixed now with 0.2.9
It works fine. thanks... but it don't show any subtitle
id need a test login to test stuff in regards to playback
have you go into the kodi subtitle settings during playback and checked if they are just disabled?
(2021-07-02, 03:48)matthuisman Wrote: [ -> ]id need a test login to test stuff in regards to playback
Subtitles has worked for me, as other audio options, thanks for fixing it
the subtitle setting it's enabled.
If you want to contact me to give you my username
@matthuisman
I have other regional accounts (Latin America)
I can confirm that Latin American accounts can be logged in in the United States. And it works fine.
If you need to test I can provide help or an account.
Of course there are currently subtitle issues, basically the same as with Paramount+. It is highly likely that the external subtitles will not display properly. Also it seems that prolonged playback may cause Kodi to crash.
I have tried to switching from USA>LATAM and no success. From my friends in Mexico they say some vpn work to switch from their catalog to US. Anyhow, other accounts from different countries work?
The resolution on Windows will always be 540p? Sad
(2021-07-03, 08:30)27hectormanuel Wrote: [ -> ]From my friends in Mexico they say some vpn work to switch from their catalog to US. Anyhow, other accounts from different countries work?
Please do not forget we have a VPN policy (wiki) on this forum.
(2021-07-03, 08:37)Klojum Wrote: [ -> ]
Thank you for the reminder.
(2021-07-03, 08:31)27hectormanuel Wrote: [ -> ]The resolution on Windows will always be 540p? Sad
youd need to ask HBO that
