yeh, still not 100%.
we will need to wait for the IA update
actually, my pr below may help:
https://github.com/xbmc/inputstream.adap...-688670846
(test builds listed there)
that fixes some audio issues for others..
Im trying to get the other PR author to also include the above so we have a build with both to test
(2021-08-06, 06:41)Wagg Wrote: [ -> ]I am getting lots of dropouts with the Atmos tracks on HBO Max. The other tracks seem to be fine. I rebooted my shield, no difference.
Atmos works fine on the D+ addon.
Edit- Oddly I am not getting any dropout with the Atmos track on The Suicide Squad, yet with WW 1984 and ZS’ Justice League I am.
Yes, there is the same problem, AC3 also loses audio but intermittently after about 40 seconds of playback. dd+ 5.1ch is perfectly fine.
(2021-08-06, 06:42)matthuisman Wrote: [ -> ]yeh, still not 100%.
I am using this IA build but am still getting dropouts. But I get your meaning, it's a work in progress. No worries, I can always use the official app (which I hate).
I just noticed today that I can't get anything to play in HD. I looked through settings and couldn't find anything to force it.... any ideas?
Are you android l1 secure device? Have you enabled L1 secure device in the addon settings?
Does it give you the hd quality in the quality select dialog and then not work, or just doesn't show the option?
I had thought about the possibility of the freeze being caused by problems in the adaptive inputstream and I looked for help on the forum about it, but I got the following answer: "Not necessarily a problem with inputstream.adaptive. Looking at the log the audio stream gets a 400 response: ERROR: AddOnLog: InputStream Adaptive: Download
http://127.0.0.1:52103/https://cmaf.lln... .3/a/a4.mp4 failed with error: 400 After this stream stops downloading any further segments. @
matthuisman, is this something that can be fixed? Thanks for all your work on this amazing add-on!
What are you playing when you get that error?
Are you physically in a supported country?
(2021-08-08, 03:23)matthuisman Wrote: [ -> ]What are you playing when you get that error?
I was watching Epitaphs (season 1). And yes, I am in a supported country (Brazil).
looking at your log from the other thread,
your using Kodi 18.9 LibreELEC 9.2.8 on RPI and IA version 2.4.8
you were actually playing Mulher de Fases S01E13 (A shrink and a surfer)
with audio Portuguese AAC 2 channels and video stream is the h264 960x540
and it looks the audio error occurred about 35s after starting playback
I've just tried the same (on windows 18.9) and played for first 2minutes without issue
Can you test again the same as above, and tell me when the video stops?
If you select the lowest quality - does the same happen?
(2021-08-09, 01:03)matthuisman Wrote: [ -> ]looking at your log from the other thread,
sorry for the mistake... I'll take the test when I get home. Thank you!
I tested the video mentioned above with the lowest possible resolution and ended up having the same problem when it reached 1:30... It must be a problem with my equipment (sad to admit it!), but thank you so much for your willingness!
get me a new debug log please
I played the local video in another attempt but this time with success. However when trying to watch a new video with the same specs (ie minimum resolution and aac audio), the problem reappeared. Here is the log:
http://ix.io/3vqy
(2021-08-09, 06:05)Platino 81 Wrote: [ -> ]I played the local video in another attempt but this time with success. However when trying to watch a new video with the same specs (ie minimum resolution and aac audio), the problem reappeared. Here is the log: http://ix.io/3vqy
edit: where it says "local video" read "quoted video"
