Full Version: HBO Max
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
you can disable ATMOS in the settings so it is automatically removed until it works good
(2023-01-25, 01:09)matthuisman Wrote: [ -> ]you can disable ATMOS in the settings so it is automatically removed until it works good
Of course I know that, but when I have devices and speakers for atomos at home, I prefer to look for a solution first before turning it off. if there isn't one at the moment, then I have nothing else left but to turn it off for those addons where atmos doesn't work in Kodi at the moment...
But I discovered another problem. When the Include Forced Subs option is turned off, I still get forced subtitles. This only happens with the HBO Max addon. I have it set exactly the same with the Disney+ addon and it works correctly there Sad
Is there a way to get the "Previously On" section of TV episodes?
When I watch it through my browser, the episode starts with the Previously On with the option to skip. When I watch through Kodi, it starts the episode right at the title screen.
Not sure if it would be possible, but it would be great to have a setting for "Show Previously On" and if that is set to true, it would show the Previously On section and give the option to Skip while watching the episode.
Can you give an example of a TV series where this happens?
For example I've just tested with Avenue 5 episode 2x01 and it does show the "previously on" segment on the addon.
(2023-02-23, 16:22)Doctor Eggs Wrote: [ -> ]Is there a way to get the "Previously On" section of TV episodes?
Do you have the option to "Skip Previews" set to ON in addon settings? When set to ON it automatically skips all previews...
Edit: the option is actually called Skip Intros.
Yes. I have that setting set to off.
I'm watching "The Last of Us" and when I watch it through my browser, it plays an ad for a different show (which I would gladly skip), then the Previously On, then the HBO logo and then the intro and episode.
Through Kodi, it only plays the HBO logo, the episode into and the episode itself.
I'm wondering if there are two different streams. One that has all the stuff like in the browser and then another one that just has the stuff that is presented in Kodi.
I don't get the "previously on" segment in the series "The Last of Us", not even in the web browser. Maybe those segments are in separate videos which are not available for all countries.
I need to transfer my login from one computer to another. I don't have the password. How could I do it?
Sounds fishy. But try copying the addon userdata folder
The userdata folder for Hbomax?
yes
Worked perfectly. Thank you!
Thought you should know that after the latest SlyGuy Common update installed today, the HBO Max add-on stopped showing episode names, so you just see a list of season and episode numbers. Apart from that, everything else still seems to work fine.
Also, thanks for your work to date on this add-on.
Same problem
