Hello -
I’ve been using Kodi for years and recently switched to the Rapier skin after years of using Confluence and I love it.
One thing I can’t seem to locate, however, is the context menu option on a season folder to mark all items as watched or unwatched.
Is there a way I can add this myself through the interface or by editing one of the XML files?
Hi NoTolerance and welcome to the forums.
Thanks a lot for the support and kind words.
It works for me using Rapier 12 with Kodi 19 Matrix.
Which version of Rapier and Kodi do you use?
Does it work in other skins (probably not, since it's hardcoded in Kodi)?
(2020-11-23, 03:04)NoTolerance Wrote: [ -> ]One thing I can’t seem to locate, however, is the context menu option on a season folder to mark all items as watched or unwatched.
Just FYI, if you use a 'normal' PC keyboard, pressing the 'w' will also toggle the watched status on the season and its underlying episodes.
(2020-11-23, 10:11)Gade Wrote: [ -> ]Hi NoTolerance and welcome to the forums.
I'm using Rapier v11.2.59 with Kodi v18.9. This is a pretty new build, less than a month old.
Here's what I see for TV Series:
But it seems to work fine for movies:
Quote:Just FYI, if you use a 'normal' PC keyboard, pressing the 'w' will also toggle the watched status on the season and its underlying episodes.
Worst case scenario, I'll just map a key to this on my remote. Thanks for the suggestion.
