2020-11-27, 21:03
Pages: 1 2
2020-11-27, 21:28
2020-11-27, 21:33
(2020-11-27, 21:28)Karellen Wrote: [ -> ]https://kodi.wiki/view/Edit_decision_list
Where is that comskip file
2020-11-27, 21:35
(2020-11-27, 21:33)nracmo Wrote: [ -> ]Where is that comskip fileI don't know. What do you mean where is it?
2020-11-27, 21:40
2020-11-27, 22:10
My system just completely ignores the edl files and I always have to revert to kodi 17 for it to work I thought they would have fixed it by now but....
2020-11-27, 22:13
2020-11-27, 22:26
(2020-11-27, 22:13)Karellen Wrote: [ -> ]That's a lot of work just to prove what doesn't work. I'll just downgrade Kodi and assume it will never be fixed again I've been trying to figure this out for over a year, It works fine before whatever they changed on 18.* so whatever...(2020-11-27, 21:40)nracmo Wrote: [ -> ]but I cant find that file to edit it on my systemBecause they don't exist. You have to create your own edl files.
If you have them and they don't work, then provide a copy of the edl file and a Debug Log which captures you playing the movie with an edl file.
here's one of my edl files
00169.515 00170.045 1 #Muted
00237.002 00237.737 1 #Muted
00283.916 00285.077 1 #Muted
00681.527 00682.683 1 #Muted
00686.953 00687.987 1 #Muted
00693.902 00694.609 1 #Muted
00725.390 00726.373 1 #Muted
2020-11-27, 23:30
(2020-11-27, 22:26)nracmo Wrote: [ -> ]That's a lot of work just to prove what doesn't work. I'll just downgrade Kodi and assume it will never be fixed again I've been trying to figure this out for over a yearOk, great. You saved me a "lot of work" trying to help you. I'll go back to using my edl files in v18
2020-11-27, 23:39
(2020-11-27, 23:30)Karellen Wrote: [ -> ]I just don't know what to do to make it work I'm so tired of trying to figure it out. Why is it so difficult for it to just work after the update. I've reformated, started over, upgrade, downgrade, remade the files, manually edited them, there is just nothing I can do I don't know how to make debug files and all.(2020-11-27, 22:26)nracmo Wrote: [ -> ]That's a lot of work just to prove what doesn't work. I'll just downgrade Kodi and assume it will never be fixed again I've been trying to figure this out for over a yearOk, great. You saved me a "lot of work" trying to help you. I'll go back to using my edl files in v18
2020-11-27, 23:44
(2020-11-27, 23:30)Karellen Wrote: [ -> ]Sorry I'm just frustrated don't mean to take it out on you(2020-11-27, 22:26)nracmo Wrote: [ -> ]That's a lot of work just to prove what doesn't work. I'll just downgrade Kodi and assume it will never be fixed again I've been trying to figure this out for over a yearOk, great. You saved me a "lot of work" trying to help you. I'll go back to using my edl files in v18
2020-11-28, 00:27
There is a problem using your edl file. Give us some time to check out the issue.
2020-11-28, 00:32
(2020-11-28, 00:27)Karellen Wrote: [ -> ]There is a problem using your edl file. Give us some time to check out the issue.
Well I do Appreciate any help. Just let me know what I need to do
2020-11-28, 01:46
@nracmo
The good news is that developer @Fuzzard may have spotted the problem in the code here... https://github.com/xbmc/xbmc/blob/5230b6...l.cpp#L221
The bad news is that v18 has ended the development and update cycle so v18 won't be fixed.
Could you please raise an Issue report here... https://github.com/xbmc/xbmc/issues and I will confirm your report and hopefully it might be a simple fix for a developer to add to v19.
Until then, I am not aware of any other Mute facility in Kodi. IIRC, there is an add-on named ProfanityMute (or similar) but no idea how it works. https://forum.kodi.tv/showthread.php?tid=169029
2020-11-28, 01:51
(2020-11-28, 01:46)Karellen Wrote: [ -> ]@nracmo
Thanks for the info I will do that. The addon mute profanity is one thing I use it for. It takes the subtitles and generates an edl file
Pages: 1 2
