Full Version: Problems with see through skin
Hi people!
I've been trying to search for this, but I don't know even what to call it.
9 times out of 10 when I log on to Kodi with Aeon Tajo skin. I see the library of everything, but it's see through. The only way I know how to fix it is to change skin and when it asks if you want to change to that skin, press no, and Aeon Tajo will look normal again. If it's clear it makes it almost impossible to go into menus and such. Anyone know how to fix this?
Image[/url]
No idea... Try changing to Estuary, delete Aeon Tajo completely and install it again...
(2020-11-30, 10:45)manfeed Wrote: [ -> ]No idea... Try changing to Estuary, delete Aeon Tajo completely and install it again...
I tried that and it didn't work. Then I installed another skin and it had the same problem. Then I thought about that I have two profiles and the other profile uses Estuary. When I changed them to the same skin it all worked. So thanks for your help. I wouldn't have tried to unistall and all that. So it worked. Smile
