Full Version: Unable to select custom colors
After setup of my Raspberry Pi (libreelec) I selected Unity for my main profile.  I used custom colors to select each element's color.  Wow the options there.
Then I set up my kid's profile and tried to use custom colors again for more vibrant interface.  I am able to select and use any of the premade color combinations, but not "Custom".  It might be worth noting that when I selected the Unity on their profile, I had to enable it from addons, as the "get more" link in the skin selection screen was not functioning.
Was this something I did wrong in the kid's profile setup?
I will try multiple profiles on my side and see if I run into the same issues.
This is a test build on Raspberry Pi 3B+.  I had been away from Kodi for a few years and I was trying all the skins on first setup.  I don't even remember if the skin was already available or if I had to get it from the repository.  I do remember that this skin may have asked me to install additional things during the setup.  On new profiles, it does not ask me to.
Looks like a known "feature" where addons get disabled when switching profiles: https://kodi.wiki/view/Profiles#Troubleshooting
The way to re-enabled the Color Picker addon is to go to System -> System settings -> Add-ons -> Manage dependencies. Find "Skin Helper Service ColorPicker" and make sure it is enabled.
(2020-12-09, 21:42)Bumpaneer Wrote: [ -> ]Looks like a known "feature" where addons get disabled when switching profiles: https://kodi.wiki/view/Profiles#Troubleshooting
I will give that a look tomorrow. I just discovered that I can install Kodi on AT&T TV set top box (it is Android based) so I am focusing my attention on getting that set up on two locations. Definitely sticking with this clean look and the kids (12 & 9) are having fun picking custom colors. They want their own profiles!
Thanks for your continued support of this skin.
