Full Version: Ratings Gone
All of a sudden all of my RPis are missing all the ratings except IMDB. I have but changed a thing and it's been working fine for months. Am I the only one?
(2020-12-06, 21:04)hootie318 Wrote: [ -> ]All of a sudden all of my RPis are missing all the ratings except IMDB. I have but changed a thing and it's been working fine for months. Am I the only one?
Yes , All of my Rating are gone too
Can somebody tell me if this is a bug or something I messed up?
(2021-01-09, 05:56)hootie318 Wrote: [ -> ]Can somebody tell me if this is a bug or something I messed up?
We can't. We need a Debug Log that captures the issue to determine what has happened.
Are you sure your ratings are gone? Have you checked the database? If you don't know how, I can check for you. PM me the database and tell me a couple of movies that have ratings missing, and what those ratings were -imdb, tmdb, tvdb etc
Ratings works for me
(2021-01-09, 06:12)Karellen Wrote: [ -> ]
My apologies. I did not see this response. Here is the log from today. The very last step was navigating to movies.
hastebin - gurupaqahi (kodi.tv)
(2021-02-24, 19:09)hootie318 Wrote: [ -> ]
I am not sure if I have the verbiage correct. I mean my Rotten Tomato, Metacritic, and extra IMDB icons are gone.
(2021-02-25, 23:27)hootie318 Wrote: [ -> ]I am not sure if I have the verbiage correct. I mean my Rotten Tomato, Metacritic, and extra IMDB icons are gone.
It may have something to do with this error repeated through your log...
xml:
2021-02-24 10:52:39.598 T:2741617520 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|Unable to connect to 192.168.1.15:5004 : [Errno 110] Connection timed out
I don't use embycon, so others will need to assist or ask in the appropriate thread.
(2021-02-26, 01:03)Karellen Wrote: [ -> ]
xml:
I can get it with the Horizon skin in the poster view but not in Zephyr or Aura. I used to get it in Aura. I also did a new install of the OS and the Aura Skin. Same results on Aura and Horizon
I don't really know where your ratings are coming from. Are you scraping them or are they coming from one of the helper addons?
This is why I asked for your database to see what ratings you have in there.
But if you can get ratings in one skin, but not another, then it seems to be a skin problem, and I don't know if Aura is still supported.
(2021-02-27, 02:28)Karellen Wrote: [ -> ]I don't really know where your ratings are coming from. Are you scraping them or are they coming from one of the helper addons?
The ratings that I had became visible following the steps to enter my API keys in Zephyr Leia which is why I switched. Then I saw Aura and installed it and I was still able to get ratings. The ratings always took a few seconds to appear each time so I assumed they were constantly being called from the Internet or cached once loaded.
I can get them in Horizon but only in the Landscape poster or Landscape Banner view. I prefer Aura or Zephyr Leia but with those skins the ratings no longer load. I would keep Horizon if it had a List or Low List view with the ratings.
Oh well. No biggie. I only asked if it was something I might be missing or a known issue with a fix.
Aura gets ratings from skinhelper, Horizon from tmdbhelper
My problem is I am not getting Votes & Studio Logos in "Home widgets" but inside and Hubs I am getting all ratings ,how to enable votes & studio logos in HOME ? remember I am not using skin helper in matrix  for compatibility
Hubs and inside ( all ratings & votes working )
(2021-03-10, 20:13)nazim12 Wrote: [ -> ]My problem is I am not getting Votes & Studio Logos in "Home widgets" but inside and Hubs I am getting all ratings ,how to enable votes & studio logos in HOME ? remember I am not using skin helper in matrix  for compatibility
That skin it is?
I like it. Any download link?
This looks very cool, only thing missing is critics consensus on second image
