2020-12-10, 02:17
Hi
I´m using KODI installed in an Amazon FireTV - android version
My KODI was working properly until it stopped showing the servers when I click on any of the options in the repository (TV Shows, Videos, etc...)
I tried everything. Updated the version to 18.9, clear the cache, clear the data, removed all the sources and repositories, installed all again, checked all the configuration in FireTV and it continuous showing always the same message - " Couldn't connect to network server"
I removed the KODi and I did the whole installation from scratch but continue showing the message " Couldn't connect to network server" when trying to instal a new Add-on source
it seems that it´s not recognizing the internet however I´ve checked in the configuration and the internet is connected - something is blocking the connections with the sources/repositories - I´ve already checked the unknown sources configuration - it´s on
All the other applications in FireTV are working properly.
has anyone seen this error? can you help me?
