Full Version: delete individual item not working
I need to delete a particular album
From the wiki: 4.2 Remove Individual Item
1. Enable the setting Allow file renaming and deletion.
2. Using Music>Files, locate and highlight the item to be deleted- either an individual song, Album or Artist.
3. From the context menu, select Delete. Be aware- This will delete the item(s) from your hard disk.
4. Run a Clean Library.
I followed these exact steps and the album is still present in the library.  I've tried deleting the album using Kodi and deleting it via the command-line. No difference, after a clean it's still present in the library.
Maybe a similar problem with answer? https://forum.kodi.tv/showthread.php?tid=355003
(2020-12-12, 01:32)HeresJohnny Wrote: [ -> ]Maybe a similar problem with answer? https://forum.kodi.tv/showthread.php?tid=355003
Thanks for the reply.  Turns out this problem was operator error Smile
Thread marked solved.
