Hi . I use Kodi to play movies in my movie library . Always worked fine . lately for some reason when I choose to play a movie it won't play them . The screen just goes black . I am using Leila 18.9 on a Global Media box( Android ) . Does anyone have any ideas on how to fix this ??
Thank you in Advance
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
