2020-12-24, 04:34
2020-12-24, 04:36
Changelog
v.20.12.24+m
- Bump gui version
- Update color picker to matrix compatibility
- Add Cutlist and Chapters
- Add media flags for albums/songs - disc count, boxset icon, bitrate, samplerate, audio channels
- Remove startup logo
- Remove music info onup for tracks - artists/albums/music videos
- Fix for navigation in addon info
- Increase scroll speed of notification dialog
- Add check for 'addon is enabled' and automatically enable addon if disabled in skin settings
- Remove artwork beef support
- Add RSS editor and Node Editor to list of optional addons
v.20.12.24+m
- Bump gui version
2020-12-26, 09:59
(2020-12-24, 04:34)Mr. V Wrote: [ -> ]WIP progress of matrix version.
Please post your bug reports here.
https://github.com/mistervee/skin.madnox/tree/matrix
Hi Mr.V
Sorry but I’m a bit of a Noob, normally I download a Zip File to install a skin but can’t see that option on your GitHub link.
How do I download and install from GitHub link?
2020-12-26, 11:25
(2020-12-26, 09:59)Bbam Wrote: [ -> ](2020-12-24, 04:34)Mr. V Wrote: [ -> ]WIP progress of matrix version.
Hi Mr.V
Click on the the green button 'Code', then download zip.
2020-12-26, 15:17
(2020-12-26, 11:25)Mr. V Wrote: [ -> ](2020-12-26, 09:59)Bbam Wrote: [ -> ](2020-12-24, 04:34)Mr. V Wrote: [ -> ]WIP progress of matrix version.
Hi Mr.V
Yay got it thank you! Bit of a rookie error, I had chrome on mobile version...
Can I ask, Can you make the skin play nice with touch screen?
Thanks Heaps
2020-12-27, 01:15
(2020-12-26, 15:17)Bbam Wrote: [ -> ]Not sure? I do not have a touch screen device. Also the skin is coded 16:9 aspect so it will be locked to that.(2020-12-26, 11:25)Mr. V Wrote: [ -> ](2020-12-26, 09:59)Bbam Wrote: [ -> ]Hi Mr.V
Thanks Heaps
Can you point out what you cannot navigate. I might be able to add a few extra buttons.
2020-12-27, 05:05
Hi all,
There is an option for predefined themes.
If you have create a theme would like to have your theme a permanent option in the skin please post your settings.xml from '\userdata\addon_data\skin.madnox'. Let me know what you would like to call it. All options under 'Themes and Colors' will be used.
2020-12-27, 15:04
(2020-12-27, 01:15)Mr. V Wrote: [ -> ](2020-12-26, 15:17)Bbam Wrote: [ -> ]Not sure? I do not have a touch screen device. Also the skin is coded 16:9 aspect so it will be locked to that.(2020-12-26, 11:25)Mr. V Wrote: [ -> ]Click on the the green button 'Code', then download zip.
Thanks Heaps
Moving through menus on a touchscreen is non existent. (Left/down/up/right)
I ended up attached my keyboard to my Samsung tablet and it works perfect, also installed on Android TV and it looks amazing
Well done, keep up the great work
2021-01-09, 22:19
I'm having trouble with weather background and icons. I've tried different options to no avail - just blank. I don't see anything per se but I also don't know what to look for.
2021-01-24, 15:09
Good
2021-01-26, 20:50
Its working fine , I found Logo , Clear art , Movie info , Disc art etc not working on Video player . Video player need to be minimalistic and polished .
Focus & Cascade view doesn't have info .
and video buffer color is too dim and we cant see them .
and default cursor on video player always on Stop button instead of pause button .
2021-01-26, 22:11
some time when we made changes in widgets and submenu and home screen refreshed then Kodi get stopped working , and some time when we stop playing 4K or higher bitrate video then Kodi crashed .
2021-02-21, 11:04
Hi Mr .V
I just wanted to say thank you for this great skin. It looks fantastic!
I have just upgraded to Matrix and so far everything is working perfectly.
Thank you for all your hard work, it makes my media centre look amazing!
2021-02-22, 18:26
Thank you Mr. V for updating this skin for Matrix! I was really really dreading the release of Kodi Matrix because I was dreading losing the Madnox skin. Thank you!
2021-02-25, 14:13
What do you mean with (WIP).
In Leia it was under the official Kodi repo.
Please give it also to the Matrix Repo too.
