Full Version: This thing makes me crazy, movies from internet which is not in my hard drive
I have an issue when i update my local content movie, Kodi is adding movies from the internet in my library i don't know why
I just want to add my local movies in the library, how to stop kodi from getting these internet movies and mixing them in my library
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
