Sorri, for kodi 18.9 I don't know why when I install writing 'opkg install kodi-pvr-zattoo' by telnet it show me 'cannot find anything to satisfy kodi-pvr-zattoo'
It appens just with zattoo pvr.
Is this for kodi installed on the Enigma2 device itself?
(2021-01-02, 20:26)phunkyfish Wrote: [ -> ]Is this for kodi installed on the Enigma2 device itself?
Yes it is.
Infact I just installed kodi choosing from extension plugins available. I think we cannot do in other way
You need to use the forum for your image. Each E2 image creates their own version of kodi. It is not the same as the what you download from this site nor is it supported here.
If you were to use a Mac, pc or android or Linux device you could install the pvr zattoo addon.
(2021-01-02, 22:09)phunkyfish Wrote: [ -> ]You need to use the forum for your image. Each E2 image creates their own version of kodi. It is not the same as the what you download from this site nor is it supported here.
I know. Infact I installed all of the other pvr like simple client, tvheanded ecc...without issues. I don't know why zattoo is not available.
That's kodi forum?
Anyway I will try in the OPENATV forum.
It’s not available because your image did not build it. You would need to ask them why. It might be because this addon is hosted separately to the other addons.
