Hi all, I just installed amber and while it looks great in vertical, I can't seem to find the option that would make the menu items unique instead of scrolling down/up forever repating the items (movies, tvshows, etc)
Is there any way to disable that and give the scrolling hard stops to call it somehow?
(2021-01-04, 22:56)sjredo Wrote: [ -> ]Hi all, I just installed amber and while it looks great in vertical, I can't seem to find the option that would make the menu items unique instead of scrolling down/up forever repating the items (movies, tvshows, etc)
sjredo , you can choose to have a "static" vertical menu in Settings, Amber Settings, Home Layout. You can also disable "Wraparound Navigation" in the same section of settings. Like it shows here:
If you do not want any scrolling at all, then make sure that you have 7 menu items or less if you choose to use the larger font, or 12 menu items or less if you do not choose to use the larger font. Please let me know if this is what you were looking for. Thanks.
Regards,
Bart
(2021-01-04, 23:20)bsoriano Wrote: [ -> ] (2021-01-04, 22:56)sjredo Wrote: [ -> ]Hi all, I just installed amber and while it looks great in vertical, I can't seem to find the option that would make the menu items unique instead of scrolling down/up forever repating the items (movies, tvshows, etc)
@sjredo , you can choose to have a "static" vertical menu in Settings, Amber Settings, Home Layout. You can also disable "Wraparound Navigation" in the same section of settings. Like it shows here:
Regards,
Bart
That did it!
Thanks a million! This thread can be closed now I guess
