Hi mlaggner
If I have a XXX movie in the YYY directory,
how do I recognize the movie as XXX and not as YYY ?
(I would like title = XXX)
THANKS for your help !
this only works if you have multiple movies in one dir. Otherwise we take the folder name since history has shown that this is probably the better choice (nevertheless tmm can never know whether the filename or the foldername is the better choice)
I understand that tMM can never know whether the filename or the foldername is the better choice
BUT
1/ as long as the filename still works, the foldername only works if there is only one filename in the foldername
2/ tMM operation is NOT the same between filename and foldername
3/ so we can NOT use the foldername (or filename) for a particular function because of 2/ : pity ...
(personally, I used foldername to indicate the release date and the source of the movie so as not to forget them)
