2021-01-08, 21:00
@mlaggner , is this included already in the 4.1 snapshot versions? If so, how is this activated/used? Please let me know. Thanks.
Regards,
Bart
Regards,
Bart
ERROR [tmmpool-unnamed-task-T2] o.t.u.m.actions.MovieCreateThumbAction:87 - could not create FFmpeg thumb - null
(2021-01-09, 16:24)tars Wrote: [ -> ]What's the file type?mkv
Looks like it has a problem with matroska files while it creates a thumb for mp4/avi files immediately. Error log (trace.log too) doesn't help.
Code:ERROR [tmmpool-unnamed-task-T2] o.t.u.m.actions.MovieCreateThumbAction:87 - could not create FFmpeg thumb - null
ERROR [tmmpool-unnamed-task-T1] o.t.u.m.actions.MovieCreateThumbAction:87 - could not create FFmpeg thumb
java.lang.InterruptedException: null
at java.base/java.lang.ProcessImpl.waitFor(Unknown Source)
at org.tinymediamanager.thirdparty.FFmpeg.executeCommand(FFmpeg.java:72)
at org.tinymediamanager.thirdparty.FFmpeg.createStill(FFmpeg.java:51)
at org.tinymediamanager.core.movie.MovieArtworkHelper.createThumbWithFfmpeg(MovieArtworkHelper.java:1293)
at org.tinymediamanager.ui.movies.actions.MovieCreateThumbAction.lambda$processAction$0(MovieCreateThumbAction.java:84)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
(2021-01-09, 21:58)mlaggner Wrote: [ -> ]just a question - are there spaces in the folder names of your movies?@mlaggner , in my case, all of my files are mkvs, and there are spaces in the folder names of all of my movies (all are named "Movie (year)"), as well as spaces in all of my episodes' folder names (all are in "Season xx" folders).
ERROR [tmmpool-unnamed-task-T3] o.t.u.m.actions.MovieCreateThumbAction:87 - could not create FFmpeg thumb
java.io.IOException: could not create the still
at org.tinymediamanager.thirdparty.FFmpeg.executeCommand(FFmpeg.java:91)
at org.tinymediamanager.thirdparty.FFmpeg.createStill(FFmpeg.java:53)
