Full Version: Menu and Submenu
Hello
How can I add Submenus to main Menu that show files.
To explain
Menu is:
- Movies
Submenus are:
- Superman
- Marvel
- Ocean's
The goal is to hover over Menu "Movies" and then the Submenus are shown.
Once I click to i.e.: Submenu "Superman" then the movies are shown in Files view.
Thank you for your help
Heinrichxx
(2021-01-09, 11:42)Heinrichxx Wrote: [ -> ]Hello
To explain
Menu is:
- Movies
Submenus are:
- Superman
- Marvel
- Ocean's
Heinrichxx
@Heinrichxx , to change the submenu for a menu item, select "Customize Submenu" in the menu configuration dialog.  Then, use the same instructions I gave you before.  Please make sure you have added as sources the folders you want to use as submenu items.  Thanks.
Regards,
Bart
(2021-01-09, 23:03)bsoriano Wrote: [ -> ]
To explain
Menu is:
- Movies
Submenus are:
- Superman
- Marvel
- Ocean's
Heinrichxx
Regards,
Bart
Hello
I tried this
1. The Instructions brevious thread
2. Your instruction here.
Do I have to change the "Change Action" as in your Picture?
Have I to edit the "Titles.xml"?
Thank you
Heinrichxx
@Heinrichxx , as I mentioned before, you first have to add as sources the folders that you want to have show up as submenu items.  I will demonstrate here with a folder I have called "movieswitha".  In your case it could be "Spuerman".
1. Go to Videos, Files, Add Videos...
Browse to the folder you want.  In my case I will browse to MovieswithA:
Go into the folder and press OK.
You can of course change the label for the source if you want:
Press OK, and in the next dialog ensure that the content type says None, so that you can get a files view, since I understand you are not scanning this into your library:
Then, go to Settings, Amber Settings, Home Layout, Customize Home Menu and Shelves.
Go to Movies, and select "Customize Submenu"
Then add an item:
And select "Choose Item for Menu"
Select "Video Library", then "Sources", then the source you created (I will select MovieswithA):
Then select "Create Menu Item to Here".
After, ensure that you select "Files View" in the following dialog:
You can change the label for the submenu item if you wish.  You should have something similar to this:
As example, I did the same thing with another folder "MovieswithB", and now have both as submenu items for Movies:
When I choose "Movies With A", I get this:
Please let me know if this is what you were looking for.  Thanks.
Regards,
Bart
(2021-01-09, 23:47)bsoriano Wrote: [ -> ]@Heinrichxx , as I mentioned before, you first have to add as sources the folders that you want to have show up as submenu items.  I will demonstrate here with a folder I have called "movieswitha".  In your case it could be "Spuerman".
Then add an item:
Regards,
Bart
Hello Bart
Thank you very much.
I will try this today.
Regards
Heinrichxx
Hello Bart
I tried exactly as explained but it did not work.
1. The movies are imported into Video Library
2. I still would like to have different submenues
Regards
Heinrichxx
(2021-01-10, 12:53)Heinrichxx Wrote: [ -> ]Hello Bart
Regards
Heinrichxx
@Heinrichxx , I am sorry that you are having issues.  It does not matter if the movies are imported into the video library.  You can configure the submenus as you want.  I think that in order for me to help you better, I would like you to tell me exactly what you want to achieve, including what is your current folder structure.  Give me an exact example, with the locations of where things are your system, of what you want for the Movies submenu, and at least one of the submenus that you want.  I would like, if possible, for you to let me know:
1. What do you want to happen when you open the Movies main menu?
  -- if you want to see all of your movies in the library (the default for this menu item), is this happening now? If not, what is happening?
  -- if you want something else to happen, what do you want to happen?
2. Where are your movies located? Can you give me specific examples of how your folders are set up?
3. What are all of the submenus that you want for the Movies menu item?
-- For each submenu that you want, where are the movies for that submenu located? Specific folder examples please
-- What do you want to happen when you click on each submenu?
Hopefully with this information I will be able to help you better.  Thanks.
Regards,
Bart
