I have a small issue where the debug overlay always loads as ON and I cant figure out why? I have tried to ToggleDebug to off and then do a full shutdown and reboot, but every time it comes back. It also reappears after a skin refresh. Any ideas what i may be missing? I looked in all the settings files.
Check your advancedsettings.xml file. You may have added <loglevel>2</loglevel>
(2021-01-14, 06:28)Karellen Wrote: [ -> ]Check your advancedsettings.xml file. You may have added <loglevel>2</loglevel>
I looked and thats not it.
This is a fresh install of everything. Problem only happens on the skin Im working on.
(2021-01-14, 06:20)CoolRunning Wrote: [ -> ]I have a small issue where the debug overlay always loads as ON and I cant figure out why? I have tried to ToggleDebug to off and then do a full shutdown and reboot, but every time it comes back. It also reappears after a skin refresh. Any ideas what i may be missing? I looked in all the settings files.
Is it set to "true" in addon.xml ?
(2021-01-14, 19:41)Hitcher Wrote: [ -> ] (2021-01-14, 11:22)ontap Wrote: [ -> ]Is it set to "true" in addon.xml ?
^ This.
IIRC until the toggle was added this was the only way to turn it on.
scott s.
