2021-01-14, 23:24
Hi, I have two linux Mint desktopĀ pc's and one R/Pi installed with official (I believe) kodi.
1st pc System info screen says Version info - Build: Kodi 18.9 (18.9.0) Git:202001024-0655c2c715 Compiled: 2020-10-24.
2nd pc System info screen says Version info - Build: Kodi 18.9 (18.9.0) Git:202001024-0655c2c718 Compiled: 2020-10-24.
The Pi System info screen says Version info - Build: Kodi 18.9 (18.9.0) Git:newclock5_18.9-Leia Compiled: 2020-10-25.
All have TVHeadend and Mythtv addon backends
When I use kodi on the second pc to stream live tv or play back recordings from either backend (with the other disabled) the picture is garbled
screenshot here https://drive.google.com/file/d/1dgAtZ0l...sp=sharing
On the same pc I can stream direct from either backend to Celluloid and it plays perfectly both live TV and recordings
The first pc and the pi stream through kodi without any issues
To me (happy to be corrected) that says the the issue is with Kodi install/setup on the 2nd pc. I can't see anywhere in the set up to make changes and I've tried searching these forums and google (perhaps with wrong keywords) and not found an answer, so if anyone can point me in the right direction I should be looking for a solution or suggest keywords i should use to search with that would be great.
