2021-01-17, 06:55
2021-01-17, 07:00
@semmen1013
Please enable Debug Mode in Settings>System>Logging and reproduce the same log.
Which language are you trying to scrape?
2021-01-17, 07:32
(2021-01-17, 07:00)Karellen Wrote: [ -> ]@semmen1013the same log with debug mode: ukizuyofeh (paste)
I scraped in Chinese which has no problem before.
2021-01-17, 07:52
Hmm, I cannot see what is causing the problem.
In your first log you had an issue with Language, but that seems to have disappeared now. I tried scraping Bravehart using 勇敢的心 and it scraped ok for me.
Can you please change scrapers to this one and test if it works for you... https://kodi.wiki/view/Add-on:The_Movie_Database_Python
It is available using the Get More button in setting 5b
2021-01-17, 10:12
(2021-01-17, 07:52)Karellen Wrote: [ -> ]Hmm, I cannot see what is causing the problem.Changed to the scraper you suggested, still not working.
logs here: ifiyicuror (paste)
2021-01-17, 10:16
(2021-01-17, 10:12)semmen1013 Wrote: [ -> ](2021-01-17, 07:52)Karellen Wrote: [ -> ]Hmm, I cannot see what is causing the problem.Changed to the scraper you suggested, still not working.
maybe, it's a network problem. Can this be diagnosed from the log?
2021-01-17, 10:41
2021-01-17, 10:48
Oh, I see you are having problems with TV Shows also...
Are you in China? Maybe there is a problem with accessing TheMovieDB.
Can you provide another log as above, but in Settings>System>Logging enable Component Logging and select libcURL... https://kodi.wiki/view/Log_file/Easy#Ena...ic_logging
xml:[metadata.tvshows.themoviedb.org.python (1.1.26)]: failed to reach the remote site
Reason: [Errno 110] Connection timed out
2021-01-17, 12:23
(2021-01-17, 10:48)Karellen Wrote: [ -> ]Oh, I see you are having problems with TV Shows also...found out the reason...it is a network problem, and i solved it. Thank you a lot~
2021-01-17, 20:41
Thread marked solved.
