Full Version: Can i copy files from amber leia to amber matrix?
thinking of updating to kodi 19 and since i want a clean install i was wondering if i can simply replace the files in the folder script.skinshortcuts with the ones i have from amber leia or any issues there? just don't want to go over all the shortcuts i made again in the new install
thank you
(2021-01-17, 22:12)billyrene Wrote: [ -> ]thinking of updating to kodi 19 and since i want a clean install i was wondering if i can simply replace the files in the folder script.skinshortcuts with the ones i have from amber leia or any issues there? just don't want to go over all the shortcuts i made again in the new install
thank you
@billyrene, as far as I know, that should work. You need to copy all files that have Amber in the name from the folder <userdata>\addon_data\script.skinshortcuts, and you also need to copy the script-skinshortcuts-includes.xml from the skin's 1080i folder. Please let me know how it goes. Thanks.
Regards,
Bart
(2021-01-18, 13:19)bsoriano Wrote: [ -> ]
thank you
Regards,
Bart
thanks so much for the info. i'll let you know as soon as i go ahead
just for  information purposes. i copied the files mentioned above from kodi leia 18.9 to the latest kodi 19 RC and it all seems to be working just fine
(2021-01-26, 14:54)billyrene Wrote: [ -> ]just for  information purposes. i copied the files mentioned above from kodi leia 18.9 to the latest kodi 19 RC and it all seems to be working just fine
@billyrene, thanks for confirming.
Regards,
Bart
