2021-01-19, 00:03
Hi!
I am using LibreELEC 9.2.6 with Kodi 18.9 (18.9.0) on a Raspbery 4B 4GB. My goal was mainly to watch drone videos in 4k on my TV. The TV's built-in video function stutters, due to the weak ethernet adapter, which for some mysterious reason only supports 100Mb/s.
Unfortunately Kodi stutters very much on playback, the framerate is about 2 frames/s, I would guess. Strangely the on screen video information (key 'o') says that the playback is hardware supported. I doubt that, because during the playback the H264-decoder is idle, while it runs with 361Mhz when playing H264-encoded videos in FHD. Also see this screenshot. The video shown there has these specs:
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=29
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1 min 3 s
Bit rate : 99.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.402
Stream size : 762 MiB (100%)
Encoded date : UTC 2020-05-21 20:05:22
Tagged date : UTC 2020-05-21 20:05:22
Codec configuration box : avcC
Is there a way to get the hardware decoder handle 4k videos?
Format : AVC
Codec ID : avc1
Color space : YUV
Bit depth : 8 bits
