Full Version: "Scrape episode" doesn't get any info, but rescraping entire show works fine
Hi all
This might end up being me doing something wrong as I'm still getting used to using Ember, but I've found an odd problem.
I have a couple of shows which if I add a new episode, then "(Re)scrape Episide" it renames the file and gets a thumbnail, but doesn't get any episode info.  When it renames, it should be "s**e** - <episodename>.mkv" but, since there's no episode name it renames to "s**e**.mkv".  If I Re-scrape the entire show it downloads all information and everything is fully populated, so I don't think it can be the source that is missing info.  Other shows work fine... add an episode, refresh library, rescrape single episode and it gathers everything it should.
I'm hoping this is something I'm doing wrong as it's a pain having to rescrape 200+ episodes in order to get info for just one... can anyone point out what's up, or where I can look to investigate further?
I'm using Ember 1.5.0 x64, scrapers are TVDB, IMDB.
Thanks very much.
