2021-01-19, 11:14
Hello,
There exist the function to export-/import a video library. This can be executed via "Settings -> medium -> Library ->
- cleanup library
- export library
- import library"
The export works fine and creates a dir called "kodi_videodb_2021-01016". There is a file called videodb.xml
If I try to import the library I cann't see the file. I see only the sub-dir (and they are empty):
- actors
- movies
- musicvideos
- tvshows
The file videodb.xml is missing even the file exist at this location.
This behavior unfortunately exists a long time of KODI versions.
My hardware are raspberry 2B, 3B and 4B. On 2B and 3B is OpenELEC and on 4B LibreELEC installed.
I guess this is a bug. Does anyone had success to import the library on a raspberry?
- cleanup library
- export library
- import library"
- actors
- movies
- musicvideos
- tvshows
