Full Version: Getting 2 disc movies to show up in library
I am a newbie and I have a Kodi installed on a raspberry pi. I have figured out a few things on my own but am having trouble getting the movie Ben-Hur to show up on my movie wall. There are 2 discs, so I copied 2 ISO's to my library, but when I update I only see one image. The second ISO is there if I go into the file list, but not in the poster art wall. I tried naming them disc one and two, and also cd1 and 2. I put them in a folder and still no luck. Hoping you can help me, thanks in advance.
Image https://imgur.com/c4VfHmT https://imgur.com/IWjl0Gp
https://imgur.com/kCswzZz
I hope you're able to see the photos
@davespeanuts
Normally users want two parts of a movie to show up as one movie in the library. Is this what you want also or do you want to see both halves in the library as separate entries?
Regardless, folder stacking is broken for ISO's, Bluray and DVD folders.
I recommend converting to mkv files and joining the two files into one movie.
https://github.com/xbmc/xbmc/issues/16109
