2021-01-25, 11:07
Is it possible to merge the DV code into an 18.9 64bit build? Will it replace my existing build or does it have a different bundle ID?
(2021-01-25, 09:14)DaMacFunkin Wrote: [ -> ](2021-01-25, 05:01)tvwatchzz Wrote: [ -> ]Or your files are not encoded correctly?(2021-01-25, 04:29)Angelots Wrote: [ -> ]Like I said Kodi app on the xh90 triggers dv for me. Only thing I am missing that probably never will get fixed is Dolby truehd.
So any advice how to trigger the dolby vision on the app for me? If we have the same tvs sony xh90 and it works for you that means maybe I did something wrong
(2021-01-25, 11:43)tvwatchzz Wrote: [ -> ](2021-01-25, 09:14)DaMacFunkin Wrote: [ -> ](2021-01-25, 05:01)tvwatchzz Wrote: [ -> ]So any advice how to trigger the dolby vision on the app for me? If we have the same tvs sony xh90 and it works for you that means maybe I did something wrongOr your files are not encoded correctly?
No my files are coded correctly, tried on my fiend lg oled tv with the same movie on this modified kodi and dolby vision works perfectly for him. So it's not my files, it's something to do with this kodi app that dosnt trigger dolby vision on sony xh90, dolby atmos True HD 7.1 does work thou can even send a photo of dolby atmos 7.1 working but dolby vision ain't
(2021-01-25, 11:07)gil80 Wrote: [ -> ]Is it possible to merge the DV code into an 18.9 64bit build? Will it replace my existing build or does it have a different bundle ID?
(2021-01-25, 13:56)fandangos Wrote: [ -> ](2021-01-25, 11:07)gil80 Wrote: [ -> ]Is it possible to merge the DV code into an 18.9 64bit build? Will it replace my existing build or does it have a different bundle ID?
I have updated the main post with the Leia situation.
The Leia build my @sk83 isn't updated with the changes @quietvoid made.
So to avoid more confusion I would rather have all versions in sink with each other but I can't work on 4 different versions at once.
(2021-01-25, 05:01)tvwatchzz Wrote: [ -> ](2021-01-25, 04:29)Angelots Wrote: [ -> ](2021-01-25, 03:54)tvwatchzz Wrote: [ -> ]You mean it's working on the kodi app on sony xh90 tv or the Nvidia connected to the sony xh90 with the app on Nvidia?
That's now what I'm saying. On Disney plus it's triggering the dolby vision on my sony xh90, but this new kodi modified app dosnt work with dolby vision it dosnt not trigger it for me, so how can I fix this? Can anyone help?
(2021-01-25, 14:03)Angelots Wrote: [ -> ](2021-01-25, 13:56)fandangos Wrote: [ -> ](2021-01-25, 11:07)gil80 Wrote: [ -> ]Is it possible to merge the DV code into an 18.9 64bit build? Will it replace my existing build or does it have a different bundle ID?
Thanks for your effort brother, but there has to be somebody that could take over the 18.9 builds
If I knew how to do it, I definitely would...
(2021-01-25, 13:55)Angelots Wrote: [ -> ](2021-01-25, 11:43)tvwatchzz Wrote: [ -> ](2021-01-25, 09:14)DaMacFunkin Wrote: [ -> ]Or your files are not encoded correctly?
If your Dolby truehd works within the Kodi android app of your tv than you have a gold mine, because nobody has done that yet, so dm me the photo or place to t here, I will check my settings so I can help you with the dv problem
(2021-01-25, 17:23)tvwatchzz Wrote: [ -> ](2021-01-25, 13:55)Angelots Wrote: [ -> ](2021-01-25, 11:43)tvwatchzz Wrote: [ -> ]No my files are coded correctly, tried on my fiend lg oled tv with the same movie on this modified kodi and dolby vision works perfectly for him. So it's not my files, it's something to do with this kodi app that dosnt trigger dolby vision on sony xh90, dolby atmos True HD 7.1 does work thou can even send a photo of dolby atmos 7.1 working but dolby vision ain't
Here's the photo of true HD 7,1 working
https://pasteboard.co/JLi3fCn.jpg
And the file is a Mkv and it's working on my friends kodi without problem but for me dolby vision ain't triggering
(2021-01-25, 19:43)fandangos Wrote: [ -> ]MP4 should work just fine.
(2021-01-25, 19:54)fera27 Wrote: [ -> ]Maybe my problem is that they are DL?
Here is what MediaInfo_GUI_20.09 says for the first movie:
https://paste.kodi.tv/aluxowerij
Second movie:
https://paste.kodi.tv/cuhijewoca
