2021-01-24, 14:58
I’ve been stuck for one day to try to figure out where is the “option in the add-on menu” from the Zomboided VPN Manager Add-On
I’m running KODI/OSMC on a Raspberry pi3. I’ve been successfully installed the VPN Manager and correctly configured. I’ve been able to validate several the VPN Connections but I’m not able to find a way to cycle through the connections.
The Zomboided guide cite: “You can cycle through any of the validated connections either by using the ‘Cycle through primary VPN connections’ option in the add-on menu or by using a button on your remote”
BUT
I cannot find in OSMC the entry “Cycle through primary VPN connections’”.
I’ve been surfing to find a solution, but I just can see some screenshot from LibreELEC like https://discourse.coreelec.org/uploads/d...7x291.jpeg for the thread Openvpn Setup - Add-ons - CoreELEC Forums
Any help will be super appreciate
Anyway KODI rocks! Thanks a lot!
BUT
