2021-01-25, 05:06
Artwork Dump is an add-on for Kodi that downloads artwork for media in your video and music libraries into your media file system. It only downloads artwork already added to your libraries by scrapers, NFO files, or other add-ons. Kodi 19 Matrix only.
Artwork Dump does not add new artwork to your Kodi library.
Usage
Run from "Program Add-ons" to download artwork for all video or music library items. It can also be configured to download artwork automatically after library updates.
For a wider selection of artwork types, use a scraper that provides extended artwork, such as The Movie Database Python or TMDb TV Show scraper.
Installation
Install my dev repository to get updates delivered to you automatically. After the repo is installed, Artwork Dump can be installed from "Program add-ons". Artwork Dump can also be installed with a single zip file, but you will have to update manually.
Motivation
This saves full quality artwork to the file system in the same format that Kodi exports to and imports from (See wiki for local file naming convention, example for movie artwork). Save image files locally to speed up library scanning on a new device or a refreshed library, reduce network load, and persist your preferred artwork with a longer life than URLs to web services - they occasionally change.
Prefer this over exporting artwork with Kodi - this will download the original artwork while Kodi exports images re-encoded to be optimized for GUI usage.
Call it a trimmed-down version of Artwork Beef, it is intended to work in concert with Kodi 19's full support for extended artwork from scrapers and the file system.
Source hosted on GitHub.
READ THIS if you are having problems
I need detailed information to help you troubleshoot any problems. I cannot guess at the underlying cause of your trouble, I need you to make it clear for me. The below describes how to gather that information.
Usage
Installation
Motivation
- A detailed description of the problem. What are you trying to do? What window are you on? What steps do you take leading up to the problem? What exactly do you expect Artwork Dump to do at this point? Any other relevant context will be helpful.
- I need the entire Kodi debug log file to fully understand your problem; while recording the debug log run the process that you are having trouble with.
