2021-01-27, 19:17
Started with thread Media flag for Ultra HD Blu-ray (4K Ultra HD) I tried to use the fileinfo tag in the NFO file.
Here is an example of my NFO file (e.g. "Red Sparrow (2018).BLURAY.nfo"):
Since there is no detailed description for the different sub-tags I had to guess or try to look at the source/ressources.
For the media flags I just use the filename of the corresponding .png files (but without the extension). This seems to work more or less fine.
For the given aspect ratio ("2.40") I don't see the corresponding flag icon. Since the icon exists in Estuary I think is should also be visible. What is wrong here?
With my NFO file I see the flag icons "7.1", "DTS-MA" and "1080 HD". This is more or less okay. I just wonder about the missing aspect ratio.
For languages I have several questions. On discs you have typically more languages and I'm interested in German end English. Often you have better English audio (e.g. "Dolby Atmos") than German (e.g. only "5.1") signals on the disc.
In my example it is DTS-HD MA 7.1 vs. DTS 5.1.
The sample nfo shows multiple audio tags.
Q1: What code do I have to use? "eng" should be okay and "ger" for German?
Q2: It seems that only the flag-icons for one audio signals are displayed. How does this work? Only the best? Or only the first or the last? Or somehow based on language settings in Kodi?
Q3: Are different subtitles supported? How do I have to write it in the NFO file? Am I right that Estuary does not support the display of subtitle info?
Since we often have better English audio (original audio) on discs it would be fine for me to have the info for both, English (original) and German (synced). In this case it is also good to know if there are also the English subtitles on disc (and unfortunately this is not always the case).
xml:
<movie>
<genre clear="true">Thriller</genre>
<fileinfo>
<streamdetails>
<video>
<codec>bluray</codec>
<aspect>2.40</aspect>
<width>1920</width>
<height>1080</height>
</video>
<audio>
<codec>dtshd_ma</codec>
<language>eng</language>
<channels>8</channels>
</audio>
<audio>
<codec>dts</codec>
<language>ger</language>
<channels>6</channels>
</audio>
<subtitle>
</subtitle>
<subtitle>
</subtitle>
</streamdetails>
</fileinfo>
<actor clear="true">
</actor>
</movie>
https://www.themoviedb.org/movie/401981-red-sparrow
