2021-01-30, 15:29
Hey guys,
I'm a Kodi newbie and have trouble with Simple IPTV on Libreelec 9.2.6 on a Raspberry PI Zero. I usedĀ customized local m3u list which I've downloaded from my cable router. If I select SD channels everything works fine but if I switch to HD I get strange Artifacts and the CPU rises up to 100%. I'veĀ tried several things from overclocking to disable WLAN functionality, changing to a faster SD card but nothing seems to solve the problem. I've used a clean up Libreelec installation with only one HD channel which looks like this:
I've checked the codecs information in frontend:
Maybe more intressting could be the Debug Log
The debug log shows the input from selecting/view channel until I push the stop button on remote.
Thanks for Help and Cheers!
wanselot
If I used a stream instead (e.g. https://zdf-hls-15.akamaized.net/hls/liv...aster.m3u8) everything works fine.m3u:#EXTM3U
#EXTINF:0,ZDF HD
#EXTVLCOPT:network-caching=1000 // I've also removed this line.
rtsp://192.168.0.1:554/?avm=1&freq=450&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=1&pids=0,16,17,18,20,6100,6110,6120,6121,6123,6130,6131,6170
The only difference between https and rtsp was that the audostream in rtsp toggled until unknown was displayed instead of FL,FR and no kHz or Bits was given and so no sound was outputted. But this happens only one times I thinklog:audiostream FL,FR,eac3, 32bits, 48kHz
1280x720px, 1.78AR, 50.000FPS
omx-h264(HW)
wanselot
