Full Version: help with kodi matrix, does not scrape, error when playing
hello, I'm using kodi matrix, on Windows 10, some downloaded movies don't scrap, from any information provider
also when playing some downloaded movies I get an error that reviews the log.
I'll leave catches
https://thumbs.subefotos.com/f011e692e83...8f68fo.jpg
https://thumbs.subefotos.com/3d6656b6069...15007o.jpg
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
