2021-02-01, 13:09
For some time, while a video is playing, the Kodi menu appears above the image. I have to connect a keyboard to press the TAB key and it disappears. But after a while it happens again. Someone has been the same? thanks!!
(2021-02-01, 14:55)popcornmix Wrote: [ -> ]More info is needed, especially kodi distribution and version. A debug log would include this information.
If you are on Kodi 19 it could be this issue: https://github.com/xbmc/xbmc/issues/19153
(2021-02-01, 13:09)vdj88 Wrote: [ -> ]while a video is playing, the Kodi menu appears above the image.
(2021-02-02, 11:44)vdj88 Wrote: [ -> ]the kodi version 16.1 (libreelec version 7.0.2 (kernel 4.4.13)).
(2021-02-02, 12:23)Klojum Wrote: [ -> ]Thanks.(2021-02-01, 13:09)vdj88 Wrote: [ -> ]while a video is playing, the Kodi menu appears above the image.
How about a screenshot of that Kodi menu happening?
That is an almost prehistoric version... If you can, please provide Kodi's debug log (wiki) for more internal details.
(2021-02-02, 17:36)vdj88 Wrote: [ -> ]Hello, i only have librelec.This is a crash log. Might not be the best to show what is going on.
The kodi log:
https://drive.google.com/file/d/1g35qMA4...sp=sharing
than you very much
(2021-02-03, 09:17)Klojum Wrote: [ -> ][font][font]Nada en el archivo de registro se destaca para mí en este momento. [/font][font]Tal vez sea una falla con la versión anterior de Kodi que se ejecuta en el sistema operativo Android anterior junto con la configuración de rotación. [/font][font]Es posible que la actualización no sea una opción con cierto hardware de Android. [/font][/font][font][font]thanks all, i will try to use the a new version.[/font][/font]
[font][font]Puede optar por una configuración 'simple' de Raspberry Pi 3B + o 4B y ejecutar la última versión de Kodi en eso. [/font][font]Algunos consejos adicionales de los clientes (¿se le permite estar abierto durante Covid?) Deberían pagarlo fácilmente.[/font][/font]
(2021-02-03, 10:37)Klojum Wrote: [ -> ]I never knew that I could write in Spanish...
