I have been running 2 RPI3's for a number of years all hardwired to ethernet - somewhere along the way video add-ons have been breaking - youtube abc cbs nbc slingtv southpark adult swim comedy central pluto - click the add-on - spinning circle - rinse repeat - Are there any WORKING PI video add-ons anymore? Do i need different hardware? THANKS!! I'm running Kodi 18.9.0 / LibreELEC 9.2.6
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
