Full Version: AdultScraper for Ember released
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
(2021-11-11, 11:40)saeed3ied Wrote: [ -> ]hi
i got this error on some movie after activate Search Actors' images on TMDB.
pic
Hi @saeed3ied,
What version do you use?
Could you send me the log file?
Yes it Does, I use it all the time on there without the plugin. When I use the Plugin I can use it but when I open Settings to configure it freezes.
and thank you for putting that on the todo list, I've been doing them all by hand and its so tedious. The Straight films have been so easy with this program. You're the best.
hi
i tested again and it's work fine.
thank you.
Sometime there is missing actors when using the scraper. Is there a way to complete the search on IAFD for the remaining missing actors ?
The IAFD database for the actors is big.
I am actually working to add all the missing actors one by one manually....it will take the rest of my life...LOL...just a drag and drop from the web page on the actress should really help saving time.
Thanks again this is a really big improvement for Ember
(2021-11-28, 03:33)slappy Wrote: [ -> ]Hi,
Hi @slappy,
Have you tried the TMDB actress download feature? (You have to enable it under Edit > Settings > Scrapers - Data > AdultScraper > "Scrape actors' images from external sources")
I'll check the possibility of downloading artists' images from IAFD as well.
I'm having an issue with scraping AnalVids.com stuff. I have a number of vids in a separate folder and each have been identified as AnalVids by Adult Media Manager. My problem comes when trying to scrape the data. Scraping from the Scrape Movies dropdown just hangs but I can scrape using the right-click Change Movie option, Re-scrape Movie. The problem is that it only works once. If I try another movie it just times out. I have to close the app and restart, then I am able to scrape that single movie using the same method but only once before having to restart again.
If I try multiple movies with the Re-scrape right-click it will sometimes do more than one movie without timing out but more often than not, it will not.
Thank you
Could you please add LegalPorno.net scraper?
Thank you!
Hi Guys,
v0.8.0-BETA.4 is available.
For details and download visit https://github.com/adultmm/AdultMediaMan...8.0-BETA.4 page.
Any remarks are very welcome, as usual. Smile
(2021-11-30, 22:03)fretzcaporeal Wrote: [ -> ]Hi,
Thank you
Hi @fretzcaporeal,
Which version do you use?
Could you send me a log file?
(2021-11-30, 22:06)fretzcaporeal Wrote: [ -> ]Could you please add LegalPorno.net scraper?
Thank you!
I'm already working on it, so this scraper will be available in the next version.
I have separate installs of 0.8.0-BETA.4 and 0.7.8. These are running on Win10 on an i5 with 32GB RAM.
I'm copying a smaller sample of the vids I'm working with into a test folder and will submit you a more complete report and clean logs after I've rerun with debugging in mind. Will get back to you shortly with the logs. This will all be specifically for AnalVids.
Wasn't expecting such a rapid reply, lol. Good on you!
Here are some screencaps and a log file. I added the folder and hit Scrape Files, All, Automatic, All Items. I only makes it through the first file (does a pretty good job with that one). I eventually have to kill the process. Next I'll try to get through more than one using Ask.
https://www.dropbox.com/s/dnvlej18z11lvq...ds.7z?dl=0
Made it through three this time, with Ask choice.
https://www.dropbox.com/s/mcvxlgvkggrbz0...sk.7z?dl=0
Second Pass with Ask allowed me to use the dialog to get the two not found (AnalVids' issue, not app's) and finished up the rest. Nice!
https://www.dropbox.com/s/af7dhhlfjx648b...s2.7z?dl=0
