Full Version: AdultScraper for Ember released
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
IS it hard to add new sites for scrapers? In the world of porn, there's a lot of sites!! A lot of self pornstar site too... Can we help? How can we add our own scrapers? BTW GREAT works!!
(2021-12-20, 14:02)eduardomtz Wrote: [ -> ]Hello friend, Data18.com returned, it is better than the information of the sites, you can add it there are 99% sites and movies, so it is not necessary for me to work in more
good afternoon
Hi @eduardomtz,
I'll check the possibility to implement a scraper for this site.
Thank you
(2021-12-29, 16:20)CMDRTaco Wrote: [ -> ]Is there a way to use other fields like Studio, release Date, and Actors in the file renamer?
HI @CMDRTaco, I can't support it on the plugin level, so you should ask for this feature from Dan in the original EMM forum.
Have a few more that I would be great if you added to your "to do list". I think data18 will cover a lot of these sites.
4k.com? Loan/Debt/Old/Fist/Hunt/Daddy/Stuck/Rim
5KPorn
BadDaddyPOV
Bang / subsites
TeamSkeet subsites? BadMilfs/NotMyGrandpa/PervDoctor/PervTherapy/TinySis/SisSwap
cumlouder and subsites
CastingCouch-HD
joymii
Karups
KinkyFamily
LethalHardcore
porncz subsites
MetArt / subsites SexArt
MyLifeInMiami
NFBusty
Penthouse / Gold
PrettyDirtyTeens
Private
ProducersFun
Tonightsgirlfriend
x-art
(2021-10-20, 15:49)beuter Wrote: [ -> ]Hi, sorry was offline for a while.
Seems to be working better! Although the latest beta gives a frequent error. When trying the .2 it works fine.
Also, Tushy, blacked and tushyraw do not download images anymore for the newer videos.
Small request : is private.com beeing added in the supported sites ? Thnx!
Hi @beuter,
The new v0.9.0-BETA-1 version now handles WebP images and the Private.com scraper is also added.
Try it!
(2022-01-16, 17:57)adultmm Wrote: [ -> ]
good afternoon
Hi @eduardomtz,
Thank you
Hi @eduardomtz and @slappy
Unfortunately, there is a problem with the data18.com site. It doesn't serve the images without the appropriate referer, so the images on the site cannot be hot-linked, and used in EMM. You can try it yourself, just copy the URL of any poster to another browser window. So we should have a server to proxy the images on this site. Something like this: https://myimageproxy.com?image=https://www.data.18/image-from-the-site-jpg&use-referer=https://www.data.18 The image proxy download the image with the given referer and return it. It's not a big deal to write a proxy like this, but I have no server to run the code.
Does anybody know an online service for this task?
I'm thinking about the solution...
Hi mate, I really appreciate your work!!!
But I encountered an error (403) Forbidden on some sites (tiny4k.com, povd.com, passionhd.com, castingcouchx.com, puremature.com, holed.com) - whereas lubed.com (the same network and website layout) works like a charm...
Besides: tried it on different machines (win 10 and Win 11) with the same result
cheers
tolotos
(2022-01-24, 18:38)adultmm Wrote: [ -> ]
good afternoon
Hi @eduardomtz,
Thank you
I'm thinking about the solutioN
https://github.com/PAhelper/PhoenixAdult...09d59569cf
hello thanks for working on this I am very grateful , I do not have much knowledge but I tried this complement for plex and it manages to scratch the image maybe it will help you a little , much respect for you
(2022-01-24, 23:58)Tolotos68 Wrote: [ -> ]Hi mate, I really appreciate your work!!!
cheers
tolotos
Hi @Tolotos68,
What version of AdultScraper do you use?
Cheers
(2022-01-25, 21:45)adultmm Wrote: [ -> ]Hi @Tolotos68,
Cheers
The newest beta, I suppose...
I did an install of AdultMediaManager.v0.9.0-BETA.1.x64.exe yesterday... Info says AdultScraper_Data (Revision: 0.8.0.0) and AdultScraper_Image (Revision: 0.8.0.0)  Huh
(2022-01-26, 00:57)Tolotos68 Wrote: [ -> ]
Cheers
Hi @Tolotos68,
Don't worry about the version number, I forgot to update it.  Shy
The 403 error was caused because Google "detected unusual traffic from your computer", and shows a reCAPTCHA page. In the next version, I'll detect this case and try to use the Tor proxy. Maybe it will help.
Now you can wait some hours and try to rescrape the movies. (I got 403 last night, and now it works again.)
Sorry, we haven't had a perfect (free) solution to search on Google.
Cheers
Thanks, I'll give that a try
(2022-01-26, 13:30)adultmm Wrote: [ -> ]
Cheers
No Chance, 403 again...
Hello friend, thank you for creating such a beautiful Adult Scraper for Ember. Please implement scraper for data18.com in future.
is there a way to export data to Ant Movie Catalogue (windows) for offline viewing without KODI or PLEX. I need database with images only.
