Full Version: AdultScraper for Ember released
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
(2022-03-12, 21:23)josavvyy Wrote: [ -> ]When scraping Bang it will not choose the correct scraper-I have to and manually select each time. I've tried every combination of www.bang.com names on both the files and the scraping folder. I am also getting a webbrowser execution timeout expired when searching bang
HI @josavvyy,
I tried one other thing in v0.10.0-BETA.3, maybe it could help. Please, test it.
I did not get the error that I was getting but it still won't match the site. I have to enter the site name manually.
(2022-03-17, 23:59)josavvyy Wrote: [ -> ]I did not get the error that I was getting but it still won't match the site. I have to enter the site name manually.
This is the better case. Smile Could you send me the full path of the file? Thanks
Bang! works fine! i couldn't get a match with Bang! but when I renamed the folder to www.bang.com it worked this time. Thanks! And the data18 scrape is working much better
Now it looks like the Porn DB scrape isn't working
(2022-03-20, 15:51)josavvyy Wrote: [ -> ]Now it looks like the Porn DB scrape isn't working
Sometimes the PornDB API gives a 404 NOT FOUND response to the same requests. It takes minutes or hours then everything works again. I think the problem is that side, not in my scraper. I suppose you to contact the developers of PornDB, maybe they could help. Thanks
Guys, v0.10.0 is now stable and available to download. More info on my Github page
Cheers
Hi
I have this issue with other sites too
in older app version i don't have this issue. example path:
C:\Users\Downloads\k\Blacked.22.03.26.Nicole.Doshi\Blacked.22.03.26.Nicole.Doshi.XXX.1080p.mp4
For a successful match to your videos, filenames should be in the format
Site name or studio name - date (YY.MM.DD) - actors - Scene Name .[ext]
Here are some naming structures recommended:
SiteName - YYYY-MM-DD - Scene Name .[ext]
SiteName - Scene Name .[ext]
SiteName - YYYY-MM-DD - Actor(s) .[ext]
SiteName - Actor(s) .[ext]
(2022-03-31, 09:27)saeed3ied Wrote: [ -> ]
Hi
Thank you @saeed3ied,
It's a bug, I'll fix it in the next version.
(2022-04-02, 14:55)adultmm Wrote: [ -> ]
Hi
Hi @saeed3ied
it has been fixed in v0.10.2.
Cheers
(2021-02-20, 19:05)strubdog Wrote: [ -> ]Not sure if this possible, are you able to add ManyVids as a scraper source.
Also, please add the sites for the Vixen Media Group (Blacked, Tushy, Vixen)
Hi @strubdog,
ManyVids scraper is now available in an early alpha version: https://github.com/adultmm/AdultMediaMan....0-ALPHA.2
Any remark is very welcome.
Hi Guys,
A new BETA version is available! - v0.11.0-BETA.1
For more details and to download visit the release page on GitHub.
Enjoy! Wink
(2021-04-05, 22:22)adultmm Wrote: [ -> ]
(2021-04-05, 11:02)Gary2604 Wrote: [ -> ]Just started using Ember and this 'adult' version which is working great for the most part (thanks!) but have a few questions/issues.....sorry if I'm doing things wrong:
1. I have selected Adult Scraper, IMDB, TMDB under the Movies - Scrapers Data. I can see that the program steps through the selected scrapes in turn. I get a strange fourth scrape 'Marc Dorcel' which seems to be on by default. Can this be dissabled or am I doing something wrong.?
2. The search on the IMDB database seems to have some problems. Titles that are there are reported as not found, e.g Lingerie Busters (1992), Over Easy (1978), The Devil and Mr. Jones (1975), Private Gaia 5, The Temptations of Clarisse (1998) ................ some obscure titles I'll admit but they do exists in IMDB but are not found. File names exactly as shown here.
3. The manual entry of the IMDB number does not seem to work. The title seems to be found but the databse entry is never scraped, it just seems to cycle through more database scrapes. Maybe this feature has not yet been implemented?
4. The 'frame extraction' feature does not seem to work correctly. When you open the movie the image is fine but when you try to step through to find an appropriate frame the aspect ratio changes and image distorts, the saved frame is also distorted.
Thanks for your efforts on this!
Hi @Gary2604,
1, AdultScraper uses TMDB, AdultDVDEmpire, and DorcelVision scrapers (in this order) while found all fields of the Movie. In the current version, you cannot disable any of them, sorry. Of course, I have a plan to implement it in the future.
(If you use EEM only for adult content, enabling TMDB under the Movies - Scrapers Data is unnecessary because AdultScraper uses it internally. For images, it is useful because AdultScraper - in the current version - downloads only one poster image and not supports fanarts.)
2-4, IMDB Scraper and Frame Extractor are not mine, so please, ask about them in the main forum of EMM.
(It's just an idea: Maybe IMDB search doesn't enable adult content by default. I searched for Lingerie Busters on imdb.com - without login -, but there wasn't any result.)
I hope, you'll use EMM and AdultScraper successfully.
Hi @Gary2604,
You can set the used movie scrapers in the new v0.11.0-BETA.1 version.
Cheers
@adultmm
First off, thank you so very much for this wonderful program. I didn't think I'd ever get my adult series scraped, I was manually creating nfo files for them. Even though I have to scrape them as individual videos rather than TV Shows with a few quick edits they can be turned into TV episodes.
Is there a way to set TMDB as the default or first choice and IAFD second choice for actor thumbs for videos?
Could you add Dirty Flix network and sites?
Thanks again.
