Full Version: AdultScraper for Ember released
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
I get the following error when trying to scrape a video for "Deeper": "Object reference not set to an instance of an object".
Additional sites for you to add (if they are not on your "to do" list:
21 Sextury
DDF Network (The rest of the sites for this network, Kink only goes to a portion of this network)
Mylf
New Sensations
(2021-02-22, 06:56)strubdog Wrote: [ -> ]I get the following error when trying to scrape a video for "Deeper": "Object reference not set to an instance of an object".
21 Sextury
Mylf
New Sensations
I cannot reproduce this error for Deeper. Could you give me some more information: what movie did you try? what was the search title? Thanks
Here are what I am seeing, First image is search terms and file before running the "re-scrape". 2nd image is the error.
(2021-02-22, 16:15)strubdog Wrote: [ -> ]Here are what I am seeing, First image is search terms and file before running the "re-scrape". 2nd image is the error.
I tried with exactly this folder structure and file name, but I cannot reproduce the error. Maybe it can depend on some settings. Could you paste your log here: https://paste.kodi.tv/ and send me the link? Thanks
Here is the link:
egojaxuzim.kodi (paste)
(2021-02-22, 18:35)strubdog Wrote: [ -> ]Here is the link:
Thank you, I've found the problem. I'll fix it in the next version.
For now, there is a workaround: you can set the "Convert genre case" to "No change" if the video has no genre. (Vixen Group scraper has not supported genres yet - they aren't visible on the site as well. I think I've found a way to do it. I'm trying to release it in the next version.)
Right, that makes sense. You can view genre's on the site, but only if you have or had a membership.
(2021-02-20, 20:19)adultmm Wrote: [ -> ]This thread is perfect to report errors or ask for new scraper sources
Thanks for your module!
Would you consider to add support for dorcelvision (different languages) and puretaboo?
(2021-02-28, 02:11)asking2 Wrote: [ -> ]
@asking2 PureTaboo'll be available in the next version, I'm already working on it. Smile I'll also check the possibility of Dorcelvision.
21 Sextury
Mylf
New Sensations
Hi @strubdog , The new version I've released now supports NewSensations.com, but unfortunately, the site doesn't contain any genre or category information. Although the URL of the videos contains some of them, so if you collect a list of possible genres, I could implement reading them from the URL.
Dorcelvision is working really great! Thanks a lot!
With Puretaboo it crashes when I try to scrape "Artifamily". Can you check that out?
Log: "Category with empty name, id ="
(2021-03-11, 21:59)asking2 Wrote: [ -> ]Dorcelvision is working really great! Thanks a lot!
Of course, I'll check it. Thanks for the error report.
(2021-03-14, 20:37)adultmm Wrote: [ -> ]
@asking2 it has been fixed in the v0.5.12 version.
Thanks! Good work!
I'm noticing when I try to scrape a particular video, the scraper is not picking up the information. I have tried by both pornstar/actress and scene number. Is this an issue with the site's database or do you have to manually input this particular scene? The scene is currently available on the site.
