2022-09-20, 12:23
2022-09-20, 17:44
(2022-09-19, 10:45)Juan Mortyme Wrote: [ -> ]@adultmmHi @Juan Mortyme,
Greetings, I have a couple of things to inquire about.
(2022-09-19, 10:45)Juan Mortyme Wrote: [ -> ]First, it seems that all the actor thumbs fetched from https://images2.imgbox.com are 190x95 size which is less than useful for actor thumbs or anything else for that matter.
ImgBox is just an image storing site, used to upload unsupported or secured images, and the size of these images is the same as the original. So what is the original site where the actors come from?
(2022-09-19, 10:45)Juan Mortyme Wrote: [ -> ]Second, could you add the new Tiny Sis site, I believe it is part of the Team Skeet network?Yes, I can. It'll be available in the next version.
(2022-09-19, 10:45)Juan Mortyme Wrote: [ -> ]Thanks, good job.
2022-09-20, 18:04
(2022-09-20, 12:23)josavvyy Wrote: [ -> ]Hi, Is there a way to change the score to make scraping more automatic?Hi, It's not possible for the time being. Could you send me some examples where the auto-matching doesn't work?
2022-09-21, 00:41
It's no problem. It works ok when i try to autodetect video but I am using search video first and I want it to select the pornDB. It finds it fine when a select ask but if I saved my file as "Ashley Adams - Swipe the Slate Clean: Part Three - Brazzers Extra" it gets a score of 71.4 and doesn't auto match when I'm using the PornDB
2022-09-21, 01:14
@adultmm
When scraped from original site the proper size thumbs are downloaded which is fine but sometimes Data18 is preferred because in some cases they have more information then the original site. Some sites don't include release dates and very rarely do they list the male performers whereas Data18 usually does. So I end up scraping twice first for art and thumbs from original site then re-scraping with Data18 for more complete info. The only real problem with that approach is the better actor thumbs are overwritten, art can set be set not to overwrite.
Also I store my actors thumbs locally in a central folder and it would be really helpful if we could add a local path in the url box when editing actors, it seems it will only accept a valid url? This leaves me having to manually edit .nfo file replacing the actor <thumb>https:/url/thumb.jpg</thumb> with <thumb>X:\actors\thumb.jpg</thumb>.
(2022-09-20, 17:44)adultmm Wrote: [ -> ]They were scraped by the Data18 scraper but scenes were from Daughter Swap, Tiny Sis, Moms Teach Sex and a couple other I don't remember.
2022-09-27, 11:03
hi
VixenGroup and HookupHotshot.com not working.
2022-10-01, 16:28
2022-10-02, 09:56
2022-10-02, 18:37
(2022-10-02, 09:56)saeed3ied Wrote: [ -> ](2022-10-01, 16:28)adultmm Wrote: [ -> ](2022-09-27, 11:03)saeed3ied Wrote: [ -> ]hiHi @saeed3ied,
Fixed in v0.11.3.
Cheers
thanks,
VixenGroup still didn't work for me,i think because of Cloudflare structure changed.
Hi @saeed3ied,
Could you tell me some details? I cannot see any problem.
2022-10-02, 19:24
(2022-10-02, 18:37)adultmm Wrote: [ -> ]log(2022-10-02, 09:56)saeed3ied Wrote: [ -> ](2022-10-01, 16:28)adultmm Wrote: [ -> ]Hi @saeed3ied,
Fixed in v0.11.3.
Cheers
thanks,
Hi @saeed3ied,
2022-10-02, 20:17
(2022-10-02, 19:24)saeed3ied Wrote: [ -> ](2022-10-02, 18:37)adultmm Wrote: [ -> ]log(2022-10-02, 09:56)saeed3ied Wrote: [ -> ]thanks,
Hi @saeed3ied,
Thanks @saeed3ied,
I figured it out. It depends on your IP address. I reproduced it via a VPN.
I'm thinking about the solution.
Cheers
2022-10-03, 21:29
(2022-09-15, 08:56)saeed3ied Wrote: [ -> ](2022-09-14, 05:26)giantsfan006 Wrote: [ -> ]hi(2022-07-18, 19:17)adultmm Wrote: [ -> ]I'll check the possibility of a silent mode, or something similar.
Any progress on this? The imgbox errors make the entire process painfully slow.
I have no issues accessing the imgbox site so I have no idea why I'm getting the errors but I prefer to manually grab the images anyways.
use vpn
I use one. I've actually tried different servers and with it off entirely. Not sure what else I could try. Any ideas?
2022-10-06, 10:49
(2022-10-02, 20:17)adultmm Wrote: [ -> ]you're right.(2022-10-02, 19:24)saeed3ied Wrote: [ -> ](2022-10-02, 18:37)adultmm Wrote: [ -> ]Hi @saeed3ied,log
Thanks @saeed3ied,
Cheers
i changed my ip and it's worked.
2022-10-06, 13:31
would it be possible to implement a scraper for the following sites ?
moderndaysins.com
mom4k.com
missax.com
vivthomas.com
gangbangcreampie.com
thanks.
moderndaysins.com
mom4k.com
missax.com
vivthomas.com
thanks.
2022-10-06, 20:01
(2022-10-06, 13:31)saeed3ied Wrote: [ -> ]would it be possible to implement a scraper for the following sites ?
moderndaysins.com
mom4k.com
missax.com
vivthomas.com
thanks.
Hi @saeed3ied,
All of them are possible, and moderndaysins.com will be available in the next release.
Cheers
